Everyone enjoys a good "stuck" story
   / Everyone enjoys a good "stuck" story #2
4wd tractor with R4 tires gets stuck in the mud, big surprise. I cant imagine getting into a situation where my 4wd with R1's and a loader would get stuck. My farm is low and has a lot of wet spots. The only time I ever came close in (4) years with this tractor, I was able to easily drag myself out using the loader. I wonder if this guy didnt try the loader drag/push thing, but maybe those orange loaders are just too weak, unlike my green one. I remember when I only had 2wd tractors, I would always do the risky jobs with my second largest tractor, so that if I got stuck (happened a few times each season), I could yank it out with the bigger one.
   / Everyone enjoys a good "stuck" story #3
Re: Ready to Rumble??
Finally got the disc out of the field and back to the shed. Took the Kioti out with the forks and lifted the disc tongue out of the mud and spun the disc around. I then went back and got the IH and got it hooked up to the disc, had several scary moments when I thought I was going to get stuck again.
__________________
This was posted below but was a big-time stuck.
   / Everyone enjoys a good "stuck" story #4
Florida sugar sand & turf tires aren't friends.
I'm using an old converted horse barn for tractor storage, and was backing out to do some chores today. Front tires got hung up on the bottom railing just long enough for the turfs to spin. One thing led to another, & this is what happened next...Thank goodness for old faithful.
@Oleozz - Now that's STUCK!
@fltem06 - yeah - just needed to get something done quick I'm sure - and it turned into it's OWN project!
   / Everyone enjoys a good "stuck" story #6
Yup you sure got stuck. You could've called me up if needed and I'll pull you out with my BX24! :D glad you got out anyways.;)
   / Everyone enjoys a good "stuck" story #8
Time for pressure washer. ;)
   / Everyone enjoys a good "stuck" story #9
The biggest difference between a 2wd and a 4wd is when you get a 4wd stuck...it's really stuck!
   / Everyone enjoys a good "stuck" story #10
From my Jeep hobby...
"The difference between 2 wheel drive and 4 wheel drive is usually about a hundred and fifty feet... or 10 feet beyond your nearest winch anchor."
BENNU HYD SCAFFOLDING SYSTEM (A52706)
BENNU HYD...
KUBOTA M6800 UTILITY SPECIAL TRACTOR (A51406)
KUBOTA M6800...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
LAPTOPS AND ASSORTED POWER CORDS (A53843)
LAPTOPS AND...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
