Everlast Powerarc 200 ST
   / Everlast Powerarc 200 ST #1
Raider4044
Sweetwater, Texas
John Deere
I am thinking about buying a 220 volt stick welder so I don't have to fire up the miller bobcat every time I want/need to weld. What do y'all think about the Powerarc 200st? Is it is as good as the regular Powerarc 200? How does it weld?
   / Everlast Powerarc 200 ST #2
If you don't need / want the 120-volt option, and can justify the extra cost. Look at the PowerArc 300, that way you get adjustable arc force, and hot start. You can still Tig weld with the PA-300 with a Tig rig.
   / Everlast Powerarc 200 ST #3
I have the PA200ST and the only down side over the PA200 is a slightly lower duty cycle. A fair trade for dual votage input and lift start.
   / Everlast Powerarc 200 ST #4
No complaints on my 200ST. I did hit duty cycle one time but that was running on 120V with amps cranked to max and that was on a project that after I got it all fit and tacked together I should have taken it all back to shop and welded on 240V or made a trip to town and got some smaller rod.
A time or two I wished I had adjustable hot start, the auto hot start on the 200 is fine but I have some 7018 rod that is weird, it starts easy with new rod but if I stop half way through to reposition the rod is tough to get arc started again. I think it may be the brand rod I'm using.
   / Everlast Powerarc 200 ST #5
Just before you go to restrike your 7018 again. Take your gloved thumb and bust the "corn" off of the very tip of the rod and then restrike it. You will notice a tremendous difference. All 7018 is noted for forming a melted flux "corn" over the tip of the rod, making restrikes difficult.
   / Everlast Powerarc 200 ST #6
Thanks for the tip James. I'll try that it I ever get time to work on another project on the many I have planned. The 'Honey do list" seems to be interfering with what I think is important. Oh well, the joy of being a 2some. :)
Odd thought that the first 1# box of 7018 I bought (Hobart brand) didn't seem to do this, or at least I can't remember it doing so. may have been just burning a hole stick at a time playing with it.
   / Everlast Powerarc 200 ST #7
I do this too.
On brands where it doesn't work as good, I just run the tip across a file and ready to go :)
Stole the file tip from Jody on weldingtipsandtricks :D
   / Everlast Powerarc 200 ST #8
Real men just bite 'em off with their teeth. :D
   / Everlast Powerarc 200 ST #10
I did find that after getting P....d off that jamming the rod into the steel then quickly bringing it over the to where I wanted the bead to start worked OK. :cool2:
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
2012 Honda Pilot SUV (A51694)
2012 Honda Pilot...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
John Deere 772-A Grader (A52384)
John Deere 772-A...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
