Ever wonder how a radial engine works?
   / Ever wonder how a radial engine works? #1
MossRoad
Super Moderator
South Bend, Indiana (near)
Power Trac PT425 2001 Model Year
Really neat video and explanation.... :thumbsup:
   / Ever wonder how a radial engine works? #2
And then there was that really strange one in which the crank was stationary and the cylinders rotated.
Can't remember the name now.
Bruce
   / Ever wonder how a radial engine works? #3
Bruce
The aviation world calls them rotary engines. Just saw both types up close last week at the Old Rhinebeck Aerodrome. Neat museum there BTW.
   / Ever wonder how a radial engine works? #5
And then there was that really strange one in which the crank was stationary and the cylinders rotated. Can't remember the name now. Bruce
We machined an entire engine called a sleeve valve for a company in the 90's. The cylinder moved up and down and rotated several degrees which opened and closed ports that acted as valves. The pistons operated like a normal engine. It was a 2 cylinder, about 500cc, and made 220 HP.
   / Ever wonder how a radial engine works? #6
As a pilot I have a lot of exposure to those engines and the airplanes that carried them, one of my friends had a Corsair f4-u, powered by the the amazing R2800 twin wasp (Pratt & Whitney) 2000hp in the late thirties up to over 3000hp in the fifties, 46 litre.
The car engine that spun while the crank sat still was the Adams-Farwell. There used to be one at the Harrah's collection in Nevada. No exhaust system of course. The fuel was delivered in tubes and a variable compression system controlled power.
Cal-Fire had several P-W radials in Grummun S2 airplanes for small fire retardent drops, they have since been converted to turbines due to a lack of parts for the radials. The S2 airplanes were submarine fighters from the fifties and sixties, still fighting fires today.
   / Ever wonder how a radial engine works? #7
My first plane ride was in a DC 6 with four radial engines.
   / Ever wonder how a radial engine works? #8
I flew in many De Havilland Beavers & Otters when I worked in Alaska. They have very loud radial engines. Great planes for bush work.
   / Ever wonder how a radial engine works? #9
DC3 with two. Last ride was a 747 California - Hawaii in the last seat on a 747. Roughest ride I ever had.
Best was alos a 747, Anchorage to Seattle, red-eye special, full crew of stewardi and only 6 passengers.
   / Ever wonder how a radial engine works? #10
Loved the presentations, and learned some..Thanks.
2016 WINNEBAGO SCORPION 4014 5TH WHEEL CAMPER (A58214)
2016 WINNEBAGO...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2018 FREIGHTLINER...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56435)
2014 Doyle Dry...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
