Rotary Cutter Ever seen a Bush hog like this? Offset.
   / Ever seen a Bush hog like this? Offset. #11
It would be good for cutting around a pond.Neat looking.
Army Grunt
   / Ever seen a Bush hog like this? Offset. #12
Looks to me like the center part ( connecting pin )what would typically be the right bracket/pin has the ability to move over, note: look at the deck and see the angle iron, my guess is the center moves to this location when using it in the offset position ;)
   / Ever seen a Bush hog like this? Offset. #13
Bush Hog made offset rotary cutters years ago but not sure about now. I bought a Bush Hog 84" offset cutter about 15 yrs ago and it worked fine till I traded for an 8 footer. It was offset to the right side and the drive shaft was angled like the one above. Never had an issue --- just have to keep the joints greased.
edit/add: just checked Bush Hog website and they do offer several offset models.
   / Ever seen a Bush hog like this? Offset. #14
Looks like it is old machine to say the least. It looks like that someone wanted it differnet in design!
I see a lot of work left to make it safe and functional.
   / Ever seen a Bush hog like this? Offset. #15
I have the Hardee manual for this,you take the bolts out of the bracket and rotate the gear drive,you can see the studs sticking up out of the deck where you rotate the gearbox to and bolt it back down
DYNAPAC DBL DRUM ROLLER (A52707)
DYNAPAC DBL DRUM...
Honda EU3000is Gasoline Companion Inverter Generators (A54811)
Honda EU3000is...
2001 Ford F150 (A50121)
2001 Ford F150...
Giyi 46" Mulcher (A53316)
Giyi 46" Mulcher...
2005 Honda Accord LX Sedan (A55853)
2005 Honda Accord...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
