Ever lose the 3ph stabilizer pin?
   / Ever lose the 3ph stabilizer pin? #1
Highbeam
Super Member
South Puget Sound, WA
Kioti CK30HST
I did. The cheezy little chains they provide only hook onto a wire loop. The chains quickly get snagged and become a decoration but the pins seem to stay put pretty well by gravity.
Now what? Well I could buy a new one but then I started looking around the garage. I can weld, I can cut, I can grind. What is this pin anyway? A silly little piece of round stock.
I didn't have any round bar of the right size and a hitch pin is too big. Then I remembered that I had kept the old u-bolts from when I added little lift blocks to my half ton pickup. I have a hard time throwing away nuts, bolts, and hunks of metal that may have a use for someday. Today was the day for the u-bolts. I can make six more. Now I need some gold paint.
   / Ever lose the 3ph stabilizer pin? #2
I never lost one of those yet, but I did loose on two occasions the little spring on the lock pin for the ROPS...cag
   / Ever lose the 3ph stabilizer pin? #3
Haven't lost the pin...yet.
Like cag, I've chased the ROPs spring across the driveway more than once /forums/images/graemlins/mad.gif
Tom
   / Ever lose the 3ph stabilizer pin? #4
Nice job HIGHBEAM. Looks like you added a little length. A little more finger room. I haven't lost any...........yet.
   / Ever lose the 3ph stabilizer pin? #5
Take out the spring pin and put cotter keys pins in hole
works better, grass and weed do not pull them out
   / Ever lose the 3ph stabilizer pin? #6
CAG, I have lost the small springs (not the clip, but the spring) from the CK25/30 ROPS pins and found that if I put a little grease on the spring it will stay on the pin, or at least slide off slowly and give me a chance to catch it.
   / Ever lose the 3ph stabilizer pin? #7
Thank's for the tip /forums/images/graemlins/cool.gif...cag
Is the whole point of that spring just to prevent a rattle or is it to hold the cotter away from the ROPS. I once used a standard hitch pin from the receiver hitch on my truck to replace the factory ROPS pin setup. It worked just fine until the replacement shipped. No spring though.
I always keep a backup hitch pin in the truck just in case I break one or something.
   / Ever lose the 3ph stabilizer pin? #9
My thought is the sping is there just to keep the rattle away. I install it on the head end of the pin, not the clip end. /forums/images/graemlins/smile.gif I just looked in the part manual, and for once I was right, the spring does go on the head end. /forums/images/graemlins/shocked.gif
I use the spring between the head and the ROPS too now, seemed better to protect the cotter. It ends up holding the cotter against the ROPS with a very light force. The hitch pins you can buy are powder coated to not rattle.
Sakai SV540T Padfoot Compact Roller (A57453)
Sakai SV540T...
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
MAGNUM PRODUCTS LIGHT TOWER (A58214)
MAGNUM PRODUCTS...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
