Ever Heard of This Happening?
   / Ever Heard of This Happening? #1
Travis_R
Livingston Parish, LA
Yanmar YM2500
I was grading a gravel driveway today with my 98' 231 Massey Ferguson (which I Dearly love!). It has never gave me a problem.
It was running fine like it always does. I was chuggin' along then all of a sudden with no warning, the engine stalled like it ran completely out of fuel!...And thats exactly what it done. (and I just filled it up to the top with diesel!)
I happened to glance down to the left of the tractor and saw diesel pouring everywhere, coming from the fuel filter. I took a farther look and found the problem. The glass sediment bowl had completely broke into!!
Have yall ever heard of this happening??
The only thing I could think of is that the left front tire may have thrown up a rock and hit the bowl. I don't know what else it could be...
My main concern is how am I gonna get all the air out of the injectors!! The fuel tank that I had just filled up, is now completely dry!! I changed the fuel filter back in March of 08'. I never had to crack ANY injectors or bleed ANY lines.
If there is anything good that came out of this situation, we managed to find a few empty cans and saved most of the diesel. Also, I was just fixing to change the fuel filter next weekend! But, it looks like it'll get done a week earlier.
Thanks for any and all comments,
Travis R
   / Ever Heard of This Happening? #2
I used to deal with quite a few of these glass type sediment bowls and all of the broken ones were either hit with something or chipped and then over tightened.
I agree. I can see how over tightening would/could cause the bowl to break. But mine has been on there since 3/30/08 and the fuel filter wasn't leaking at all. I have always kept an eye on that.
Travis
   / Ever Heard of This Happening? #4
Your Operators Manual covers recovery from running out of fuel.
Fill tank
Turn valve on fuel filter to "Air".
Allow air bubbles to drain.
Turn valve to "On".
   / Ever Heard of This Happening? #5
Hello Travis. I have a 135 massey and had the same thing happen a few years back while bushoging. Bush hog apparently threw a rock and broke glass bowl. I took the filter and the bottom piece and bolt to NAPA and got the parts guy to find me a filter the right length that would work. I put it back together with new "O" rings, cracked lines at the pump and fired it up. I had intended to buy a new glass bowl, but this works just fine. Also now have a larger filter.
2008 FORD F-350 (A52472)
2008 FORD F-350...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
2021 Doyle 8 Ton Trailer Tender (A52748)
2021 Doyle 8 Ton...
2013 RAM 4500 (A50323)
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
