Ever cut an old Air compressor tank?
   / Ever cut an old Air compressor tank? #1
Western
Super Member
Wise county Texas
Kioti DK 35 now
I have a 15 year old 60 gal. Air compressor tank that the motor went out on. I was thinking of cutting open and maybe making a small BBQ smoker. I have not cut one and was curious how thick it might be?
Anyone ever cut one and have an idea of the general material thickness??
BTW, I can by a 28"x 3' piece of 3/8ths pipe for just over $100, so that is an option if the AC tank is thin walled.
   / Ever cut an old Air compressor tank? #2
BTW, I can by a 28"x 3' piece of 3/16 pipe for just over $100, so that is an option if the AC tank is thin walled.
good question...have no idea. but the shape is just right for a nice smoker or bbq.
   / Ever cut an old Air compressor tank? #3
Air compressor tank as smoker? - The BBQ BRETHREN FORUMS.
https://www.google.com/search?q=air...essor+tank+bbq&rls=org.mozilla:en-US:official
   / Ever cut an old Air compressor tank? #4
I cut up a 60 gallon air tank for scrap quite a few years ago. If I remember right it was only about 1/8"-3/16" thick. It was an old tank and the owner never blew down the tank so condensation rusted out the bottom of the tank.
3/16ths would do in a pinch I suppose since the fire would be in another box. Would hate to run it just to find it was 1/8th.
   / Ever cut an old Air compressor tank? #6
I think it will be closer to 1/8 than 3/16. and it will be rusty inside. Drill a small hole in it to see, then weld it shut.
   / Ever cut an old Air compressor tank? #7
For some reason:confused3: I was thinking they are only 10-GA.
   / Ever cut an old Air compressor tank? #8
There should be some info on the tank as to what code it is built to.
With a little research you should be able to find out without damaging
the tank or even easier just call the manufacturer and ask them.
   / Ever cut an old Air compressor tank? #9
I'd buy the. 375 wall pipe. It will be Cadillac for BBQ grill.
   / Ever cut an old Air compressor tank? #10
Buy the pipe, it will last longer than you live. The air tank is probably no thicker than 1/8" minus the layeer of rust.
Ron
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2018 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2018 Ford F-450...
2018 CATERPILLAR 320GC EXCAVATOR (A51242)
2018 CATERPILLAR...
Kinze 840 Grain Cart (A50514)
Kinze 840 Grain...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
