Ever cut an old Air compressor tank?
/ Ever cut an old Air compressor tank? #1
Western
Super Member
Wise county Texas
Kioti DK 35 now
I have a 15 year old 60 gal. Air compressor tank that the motor went out on. I was thinking of cutting open and maybe making a small BBQ smoker. I have not cut one and was curious how thick it might be?
Anyone ever cut one and have an idea of the general material thickness??
BTW, I can by a 28"x 3' piece of 3/8ths pipe for just over $100, so that is an option if the AC tank is thin walled.
/ Ever cut an old Air compressor tank? #2
BTW, I can by a 28"x 3' piece of 3/16 pipe for just over $100, so that is an option if the AC tank is thin walled.
good question...have no idea. but the shape is just right for a nice smoker or bbq.
/ Ever cut an old Air compressor tank? #3
Air compressor tank as smoker? - The BBQ BRETHREN FORUMS.
https://www.google.com/search?q=air...essor+tank+bbq&rls=org.mozilla:en-US:official
/ Ever cut an old Air compressor tank? #4
I cut up a 60 gallon air tank for scrap quite a few years ago. If I remember right it was only about 1/8"-3/16" thick. It was an old tank and the owner never blew down the tank so condensation rusted out the bottom of the tank.
3/16ths would do in a pinch I suppose since the fire would be in another box. Would hate to run it just to find it was 1/8th.
/ Ever cut an old Air compressor tank? #6
I think it will be closer to 1/8 than 3/16. and it will be rusty inside. Drill a small hole in it to see, then weld it shut.
/ Ever cut an old Air compressor tank? #7
For some reason:confused3: I was thinking they are only 10-GA.
/ Ever cut an old Air compressor tank? #8
There should be some info on the tank as to what code it is built to.
With a little research you should be able to find out without damaging
the tank or even easier just call the manufacturer and ask them.
/ Ever cut an old Air compressor tank? #9
I'd buy the. 375 wall pipe. It will be Cadillac for BBQ grill.
/ Ever cut an old Air compressor tank? #10
Buy the pipe, it will last longer than you live. The air tank is probably no thicker than 1/8" minus the layeer of rust.
Ron
/ Ever cut an old Air compressor tank? #11
Check on youtube for user ChuckE2009. He has a few vids showing the cutting of tanks for BBQs.
Or unscrew one of the inspection ports and use your finger and thumb to feel how thick it is.
Or if you can get a small visegrip C-clamp into the port, you can adjust it so that it just touches, and then take them out and measure the gap.
But remember, the bottom will be thinner due to rust.
/ Ever cut an old Air compressor tank? #12
I've never cut one, but didn't we have a thread on TBN in the past in which someone said there's a possibility of an explosion danger due to oil that migrated from the compressor into the tank?
Did a search on the web last night, seems there are BBQ forums and many guys have made them out of compressor tanks. I have read that tanks run the gamut from 1/8"-over 1/4", but seriously doubt this one is on the "thick side". I may go ahead and remove the motor, tank was only in service for about 2 years, may be able to get a caliber in some how .
If the tank is over 1/8", it should be fine for smoking since the firebox is a separate chamber (still has to take up to 300* without warping.)
I may just save the tank, could always run it parallel to my 80 gal Ingersol Rand and just buy the heavy pipe. I like working with heavier metal anyway. I was just curious after having to move it yet again yesterday:laughing:
/ Ever cut an old Air compressor tank? #14
If you cut it with a zip disc on your grinder, it shouldn't warp at all regardless of thickness. I too suspect it is about 1/8" thick just based on the size of welds on it, but that is plenty thick for a BBQ pit with a separate fire box. Schedule 40 pipe is going to be heavy to move around so light wall would be an advantage in that respect.
Gary, that is what I was thinking as well, shouldn't be exposed to to much heat over 300*. I would use my plasma for the cutting, I would be more worried about the warping (flex) under cooking heat situation. I may try to get a look inside over the weekend.
2003 International 4300 Flatbed Dump 571557 (A62613)
2003 International...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2016 FONTAINE VELOCITY FLATBED SEMI TRAILER (A61568)
2016 FONTAINE...
2022 Deere 317G (A64126)
2022 Deere 317G...
