Ever bent a SSQA lever? I can't figure out how I did it!
   / Ever bent a SSQA lever? I can't figure out how I did it!
   / Ever bent a SSQA lever? I can't figure out how I did it! #22
Own a tree farm, trees and tractors, mean you must bend stuff back to where it belongs. I bought a 24”” crescent wrench. To remove barrels from flat actions. So one day I was pushing a dead tree over, top snapped off, droppd down the front of the tractor, I stopped and backed up, it had jammed itself between the mount for the plate and the lever. Me backing with the snag stuck in the ground bent that lever pretty good. I just got the crescent wrench put the handle straight up, tightened the jaws flat on both sides and bent the handle back straight. Those handles are mild steel.
   / Ever bent a SSQA lever? I can't figure out how I did it! #25
It's one of those types of tools that will stand for months without use, or maybe even years, but will be worth it's weight in gold when you need it, because nothing else will do.
   / Ever bent a SSQA lever? I can't figure out how I did it! #26
I've bent mine a couple times in the opposite direction. In my case it was using the grapple and it got hung up on brush.
I just bent it back with a dead blow mallet. It's soft metal.
   / Ever bent a SSQA lever? I can't figure out how I did it! #27
I need to go get one now that I don't work in a shop now.
   / Ever bent a SSQA lever? I can't figure out how I did it! #28
When you hooked up one of your attachments, you accidentally got the locking lever stuck under the cross bar of the attachment, bending the handle back.
Happens to me once in a while.
What he said. I've done it too. I just bend it back
   / Ever bent a SSQA lever? I can't figure out how I did it! #29
OK. Me too. I've bent mine now a couple of times. Usually the result of being sure I had it stabbed and too lazy to get off and look. Embarrasing.....
To fixit, I get some clearance with whatever prybar is handy, and then just slip a pipe over it and bend it back; it's mild steel.
Over all, that SSQA design is kinda under-whelming. Just looking at it I have the feeling that most any designer could have done better. I haven't really looked at the JD or European QA - but the SSQA looks like some kid's first effort in metal shop.
Too many parts, too much monkey motion, springs and hardened pins plus bushings with tight clearances, questionable security, too easy to bend or break, and too hard to stab.....and I've got two of them.
But I do have to say that having a mediocre SSQA sure beats having no bucket swapping ability at alll - which is where the compact tractor FEL industry was stuck for decades. So there's some good afterall.
   / Ever bent a SSQA lever? I can't figure out how I did it! #30
bending back mild steel, no problem. but if the levers get bent in use, then occasionally one will become disengaged in use as well. & with the other engaged, well that's when the real problem begins under load
not as easy a fix with a dead blow hammer or cheater bar
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
MINI DUMPER SDLD25 (A55745)
MINI DUMPER SDLD25...
2015 Chevrolet Silverado 3500HD 4x4 Crew Cab Service Truck (A53422)
2015 Chevrolet...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2018 John Deere 333G Track Loader (A53485)
2018 John Deere...
