Evaluation of snow removal tools
   / Evaluation of snow removal tools #21
I just can't imagine driving thru the snow and packing it down and pulling a snow blade behind! Seems backwards, literally. I try to plow (with front mounted plow on truck) before anyone drives it all down, otherwise it just packs down.
   / Evaluation of snow removal tools #22
we don't get enough snow for that. If it is tall enough the front end loader knocks it down and the blade moves it off. I don't scrape the gravel up so it is not a problem. The snow is gone now and it was 70 degrees so it is not like I will have ice all winter.
   / Evaluation of snow removal tools #23
awe BP don't get enough snow for that. If it is tall enough the front end loader knocks it down and the blade moves it off. I don't scrape the gravel up so it is not a problem. The snow is gone now and it was 70 degrees so it is not like I will have ice all winter.
We do not worry about packing snow in Virginia,,,
you simply have to expose something dark,, the sun does the rest,,
I was plowing snow on Saturday,, it was 68 degrees today,,
The rear blade is perfect for this!! :thumbsup:
   / Evaluation of snow removal tools #24
For lighter snow falls under 6" I use a rear blade driving forwards with no issues, it cuts through any packing effects of the tractor and even the cars if they've only driven over a couple times. At the start of the season I do 3 passes each way and on the 3rd pass the rolling snow will start to lift the blade just from hitting the blade frame. So over this amount I turn the blade around(without taking it off thanks to the hyd top link) and push going backwards which works fine too.
With our regular small snow falls the rear blade seems to be good enough for my 1/4 mile driveway. The neighbor has a blower they don't really use but I haven't bothered to try it out as I like run the blade right on the gravel with no skid shoes. Running a blower that low seems like it would be hard on it and the tractor with 6-700lbs grinding and bouncing along.
   / Evaluation of snow removal tools #25
Exactly, it is all gone today.
   / Evaluation of snow removal tools #26
Rear blade works fine as long as it's not too packed. Just the packing from the tractor in front of the blade doesn't cause any problems for me. Just my .02
   / Evaluation of snow removal tools #27
Plows are the fastest things to use for all types of snow until things get too deep to plow.
Then blowers work great. However, blowers work best on not-wet, not-heavy, now-snowball snow.
I primarily use my blower in areas where I cannot repeatedly plow snow or on the three areas that drift high on the mile of road I clear.
   / Evaluation of snow removal tools #28
Then blowers work great. However, blowers works best on not-wet, heavy, snowball snow.
I learned that heavy, wet snow did not work with blowers when I lived in New England,,,
When I moved to Virginia, I gave my blower to the neighbor across the street.
He had been drooling about it for the years I lived there,,
I knew it would not help with 90% of the Virginia snow.
I am a "push snow only" guy now.
   / Evaluation of snow removal tools #29
The snow in my area (100 mile south of Chicago) can be wet or dry, when dry the blower is great, no piles for it to drift behind later. But when it is wet and the wind is blowing the county plows do not waste there time plowing until it quits blowing , it is blown back in under a hour if they do. With some packing and freezing for a day or two when they do plow it looks like someone dumped a 20 ton load of broken up sidewalk in my drive entrance and the blower will not work, some places I can see the gravel in the drive and 10 foot away it is 4 foot deep and my blower will not go high enough . Most of the time it is out of the north west and my drive heads out west . I find the loader is the for sure tool for me no matter what is going on. I push forwards until I get a pile and turn out into the yard to the south so all the drifting is out in the yard. Sometimes the wind and the temperature drop will freeze the top 6 inches and I push chunks the size of a pickup truck bed. When I go to town to clean drives I might have stuff, cars,houses,garages on three side and can not blow and again the street plows build a 3 to 4 foot parking block and the street so the loader is always the one I take . The snow piles have some real hang time here, might look at the same one for months.
   / Evaluation of snow removal tools #30
I would like to try one of these
Degelman | Speedblade
looked at them real hard, however there does not appear to be a trip. I would also like to try a v blade boss type plow. Which has the same trip issues. Hitting something hard in a skid loader is not pleasant. I wear my seat belt now, so that I am far enough back so head can't hit window.
Anyway have tried everything but the above, have long drive which blower works well, but have large parking area which does not work for the blower and switching is a pain. In a heavy snow the the angled straight blade pushes the machine sideways, v blade be nice in those situations. Then the ability to scope and angle for the parking areas.
PALLET OF BAR LOCKS (A57192)
PALLET OF BAR...
UNUSED RAYTREE RMA42 HYD AUGER SET (A57193)
UNUSED RAYTREE...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2008 Chevrolet Impala Sedan (A53424)
2008 Chevrolet...
2019 Ford Escape SUV (A56859)
2019 Ford Escape...
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
