Evaluation of snow removal tools
   / Evaluation of snow removal tools #1
blackd
Platinum Member
So MD
Yanmar FX24D replaced with Massey GC2400
I've tried nearly all. My exception is a rear mounted blower which I have not used, but I have had/used back blade, front end loader, front mounted snow blower and a snow plow/blade. My experience shows the plow/blade is hands down the best. It is the most flexible as far as snow depth/type is concerned. Blower is a close 2nd, but works best on heavy mostly powdery snow. As would the plow/blade.
Just to clarify my experience. My analysis is based upon both extended and recent experience in Mid-Atlantic area snows. I have plowed professionally with a truck/blade combination, but most is from my private tractor-based volunteer experience.
The other exception is that a blower is the far better tool when faced with heavy snows, as we got in the snow-megadon 2010-2011 years
   / Evaluation of snow removal tools #2
So much depends on a brood herd of factors
cabbed mule or open station
Manual or hydrostatic transmissions
power;
gas or diesel
temperature affecting fuel types
preheating or having heated storage
total weight
drive configuration
liquid ballast/wheel weights or lack there of
tire type; European snow tires/agricultural/R2/R4
chains; 2 link or 4 link standard cross chains,
V bar ice chains, grader, log skidder with
multiple European type of snow chains used
for logging and snow plowing both
The above are just the issues with the mules used
So much of the problems related to snow plowing snow blowing are related to architects and buildling layout that people fail to rule out an architects brilliant building placement with or without out buildings as relates to prevailing winds, the ability to store snow if plows are used, the ability of the machine used to push snow back and avoid getting stuck or falling into a drainage ditch as the shoulders or driveway culverts are never seen until you get that sinking feeling.
As long as you have plenty of power or time a snow caster works very well and eliminates snow berms as long as you have some place to cast it off.
Commercial parking lots are a nightmare from the aspects fo snow removal as the two car wide parking rows are a mess to deal with if you have cars that prevent clearing them.
The reason I say this is that having single rows is better for the use of snow casters as long as they have enough power to work as the snow can be cast forward and then dumped at the very end where it can be cast to the border of the property or carted away somewhere.
BUT as they want as many cars as they can pack in there the mess making from snow and ice melters that are over used only makes it worse when people should be using sand; OH I DONT WANT SAND BEING TRACKED IN MY STORE- well you should have thought more seriously about having a geothermal melting loop installed under your lousy asphalt pours and keeping the ground temperature at a constant 60 degrees to promote melting with out salt or calcium pellets or urea or magnesium chloride to send the snow melt to your shallow storm drain catch basins.
Don't get me started on those highways and the bare road policy or all American season tires and these fools telling you you don't need them.
   / Evaluation of snow removal tools #3
You did not mention a landscape rake,,,
it works great at removing a few inches of snow,,, without removing the gravel,,, :thumbsup:
(Actually,,, I had the 7 foot landscape rake on the 650 from moving leaves,, and was too lazy to switch to the blade,, :laughing:)
   / Evaluation of snow removal tools #4
I just know from experience that as with grass cutting, the more methods you have for doing the job, and I might have a dozen or more tools between the two tasks, the more likelihood there is, you won't have the right tool for the circumstances.
   / Evaluation of snow removal tools #5
Never thought of using a rake, but those gauge wheels look like they worked well keeping out of the gravel. I sold my 7' rake with gauge wheels last year and have regretted it.
Anyway, everyone has their snow implement preferences and I am no exception. I like a rear blade and FEL ssqa bucket or blade. For big snows I put a blower on the rear. After the NE blizzard last year I added hydraulic chute controls and a cutting edge to the blower. I guess I am a little OCD, because I really like the clean look that the snowblower leaves!
   / Evaluation of snow removal tools #6
In that situation, the best thing is to plow/remove several times during the storm.:thumbsup: That storm cost me a 64'X20' lean to roof!
blackd, are you deciding on a purchase or is this just a general snow tool/removal discussion?
CADPlans, did not use the rake, but the first year in the house I did use a 7' King Kutter rear mower deck. Being the only available implement, and having ~13+" of snow, the raked font end of the mower did move enough to get out the drive and subdivision. At the time we were the only residents so we were on our own. Made it out to then get a back blade. ;-)
Are you the CADplans, John M? If so, the next implement I got was a home built Cadplans FEL, built with a MetKit kit. Worked great for 7-8 years until I sold the tractor.
Rustiron, just engineered the plow from existing parts so hoping this is my final snow removal tool. I just wanted to pass on this ole man's experience for those still wondering/deciidng.
   / Evaluation of snow removal tools #9
Gotcha. We gotta have a pic of that blackd:thumbsup:
   / Evaluation of snow removal tools #10
Yea,, that is I,,,, :laughing:
:thumbsup:
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2004 Ford F-250 4x4 Crew Cab Mechanic Service Truck (A49461)
2004 Ford F-250...
HONDA EU2200EI INVERTER GENERATOR (A50854)
HONDA EU2200EI...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
