Evaluating Bobcats
/ Evaluating Bobcats #22
Maybe the CT335 has draft control?
In post #8 MtnViewRanch said one of the differences between Kioti and Bobcat is the Kioti DK35 and up DOES have draft control (maybe an option?) and the Bobcats DO NOT.
/ Evaluating Bobcats #23
I have a CT 230.with 189 hrs on it. Great tractor, but the lack of draft control is a real PITA when you are trying to grade the road, use the rear blade to plow snow, or keep the tiller in the ground. Everything else rocks. The loader will lift enough to pick rear wheel up (oops), the 3 position rollbar is key- the mid position fits in the barn. I added a light bar to the top of the ROPS because the headlights are blocked by the loader. I wanted green, but the 230 was way more bang for the buck.
/ Evaluating Bobcats #24
I actually prefer my CT335 without draft control over my 5210 with draft control for grading.
With its quicker hydraulics and variable ground speed capability it's pretty easy to let the blade dig when your cutting material, take the weight of the box back onto the hitch when you have a full blade, and simply slow up and lift a little to deposit and spread material where you want it on the fly. I've done much quicker grading work on the smaller tractor without draft control. It also works very nicely pulling a straight blade on my gravel drive.
Running 4-5 mph over a field pulling a plow draft control is awesome. It keeps you from bogging down or digging in by transfering weight from the implement to the tractor to reduce the draft load. Pulling snow over frozen ground or a running a 3 pt. tilller shouldn't require draft control at all.
PS...you can find my Bobcat easily in the snow. Just follow the purring diesel sound you hear coming from nice clear path between the snow banks.
/ Evaluating Bobcats #25
I meant finding it when you come out of the house to START clearing the snow ;)
/ Evaluating Bobcats #26
The big orange disc on each corner will give it away.
/ Evaluating Bobcats #27
I find it humorous when all everyone can find fault about a Bobcat is the color.
Every time I read the "losing the Bobcat in the snow" joke, I laff, just cuz that is all they can whine about
:thumbsup:
/ Evaluating Bobcats #28
Yup, pretty hard to fault these machines. I love my CT230. 250+ hours.
/ Evaluating Bobcats #29
The hydro should be smooth, although in low range it is sensitive.
My only complaint so far with my 235 is the key switch placement. I broke the key off after about 10 hours. Haven't replaced it yet.
Also the loader joystick is right at knee level, so if you're turned sideways in the seat, blowing snow for example, it is very easy to push the stick with your thigh. A couple of times I have made a pass down the laneway only to turn around and find the loader at full height... :eek:
:laughing::laughing:
It was similar on my DK35, and it looks like the CK35 (Bobcat CT235) may be even more vulnerable. I cut off the key and turn signal switch arm as shown in this post:
http://www.tractorbynet.com/forums/kioti-owning-operating/206080-my-dk35-modifications.html
/ Evaluating Bobcats #30
the Bobcat is actually the only white thing in the barn. It stands out nicely even before the lights are turned on.:D
/ Evaluating Bobcats #31
Look at it this way, a white Bobcat makes a better canvas for artwork.
Say, that sounds like a cool idea for a new thread.
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
Caterpillar Traxcavator service manuals (A63117)
Caterpillar...
14 Ft Long 8 Ft Wide (A61574)
14 Ft Long 8 Ft...
CATERPILLAR 525B DUAL ARCH SKIDDER (A64276)
CATERPILLAR 525B...
Caterpillar D8N Dozer Service and Parts Manuals (A63117)
Caterpillar D8N...
