European MF 1740
   / European MF 1740 #1
Agvg
Elite Member
Norway
Mf135, Ursus C-355, David Brown 995
Is it the same in the US? Not mine, was just looking at equipment at a MF dealer.View attachment 648467View attachment 648468View attachment 648469View attachment 648471 IMG_20200330_154204.jpgView attachment 648470IMG_20200330_154038.jpg
   / European MF 1740 #2
Nice setup for a compact tractor, almost no front 3 points till you get into the 200 hp range here.
And still none except for a few large ones with the hook and ball 3 points.
We used to see them as optional back in the 60's and early 70's but almost none now days.
   / European MF 1740 #3
The second picture that you can see posted , Most 3 point hitches are on the rear of the tractors in the US They will mount snowblowers on the front different mounting system...
   / European MF 1740 #4
Only 2 pictures seem to be working. The rest says it's an invalid attachment.
Anyway, wouldn't a front 3pt and PTO with normal and not so expensive implements work better? Or they just keep doing like that so they can keep their expensive proprietary mounting systems and implements?
Some of those proprietary from mounting systems seems like a pain to attach the implements and others are just prone to wear and get lots of play, which requires replacing expensive parts after some time.
   / European MF 1740 #5
I have one and I love it. No idea why tractors aren’t set up this way here in the states other than cost
Ford Enclosed Bed (A52377)
Ford Enclosed Bed...
Kubota RTV500 (A47384)
2007 Freightliner M2 106 Ambulance (A51692)
2007 Freightliner...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
