Ether option
/ Ether option #11
What about one of those heavy duty farts into the air cleaner.:eek::plol
/ Ether option #12
I use ether based starting fluid for older diesels without air heating chambers or glow plugs. WD-40 for diesels with glow plugs. Carb and choke cleaner for gas engines with carbs. All three are cheap and readily available products so don't see the need to search for anything else.
/ Ether option #13
We use brake cleaner at work... on small gas motors, (generators, trash pumps, etc) when in the shop for repairs. Seems to work well enough, and we always have it around.
/ Ether option #14
I once knew an older guy whose gasoline powered lawn mower was so worn out that to start it he had to use ether. Every time.
/ Ether option #15
^^ This is exactly what I use also. Ether starting fluid for diesel and carb cleaner for gas.
One time I tried gasoline fumes from a damp rag held near the air breather on my dozer because some recommend it over ether starting fluid. It worked fine but seemed to be much rougher on the motor so I stick with the ether. My cummins motor has a factory installed ether injector built into it as the only cold starting aid.
/ Ether option #16
Hey; I had one of those! Had to be careful when pulling the cord so as not to rip it off.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Preliminary Listing / Full Catalog Coming Soon! (A57148)
Preliminary...
2025 Swict 72in. Skid Steer Bucket (A59228)
2025 Swict 72in...
2023 CATERPILLAR 926M WHEEL LOADER (A62129)
2023 CATERPILLAR...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
