Ethanol vs non ethanol
   / Ethanol vs non ethanol #1
Backwoods Welding
Bronze Member
All of you guys running old carbureted tractors, do you recommend running non ethanol gas or is there no difference to just fill up with regular gas from the pump? Haven't tried yet, just curious as to if someone has tried.
   / Ethanol vs non ethanol #2
Depends on the engine and if it was built pre ethanol. The pre ethanol engines had corrosion issues with ethanol. A change in the metal protected the engine from the corrosion.
If pre ethanol design I would run pure gas to be safe.
I have a '58 Ferguson with the Z134 Continental.
   / Ethanol vs non ethanol #4
No choice here as ethanol is all that is available.
I have had trouble with rubber fuel lines and corrosion in the carb...
   / Ethanol vs non ethanol #5
I've put roughly a couple of hundred hours on my early seventies International using ethanol gasoline with no problems so far - knock on wood!
   / Ethanol vs non ethanol #6
Im not having any problem with the 1962 JD2010 on 10% ethanol.
   / Ethanol vs non ethanol #7
It should work great if you use the tractor regularly.
   / Ethanol vs non ethanol #8
Something that old, probably safer to use a non ethanol variety. Only if it had a track record of using E10 with no problems would I go that route. But if E10 is all one can get, there are some good fuel additives that address issues older motors might have with E10. Amsoil's Quickshot is one of them.
   / Ethanol vs non ethanol #9
Have lots and lots of hours on an old Oliver 770, Oliver 77 and a International Harvester Super C which have all been running ethanol since the mid 80s with no problems. As a side note also ran it in the 1969 roadrunner and the 1970 Nova SS. I have never seen an ethanol issue ever.
   / Ethanol vs non ethanol #10
I have to agree... the cars cars/equipment I operate at least weekly are ok...
It's the antique and collectable vehicles or seasonal items where I have all my troubles... especially older items with vented fuel tanks.
It has been a real bear in that I never had any issues for decades going back the early 1970's... the difference is night and day... I have had vehicles parked just for winter develop carburetor problems...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
Ford Super Duty Pickup Truck Bed (A52377)
Ford Super Duty...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
Case Axial-Flow Combine Wheels NO RESERVE (A55301)
Case Axial-Flow...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
