estimated cycle times (log splitter)
   / estimated cycle times (log splitter) #1
moose13
Somewhere USA
none
Hey all, i am waiting on my cylinder but will start some fabrication tomorrow on a log splitter. I was curious on how to calculate cycle times?
I have a 6.5 hp Honda, 13.6 gpm pump, and a 4"x24" stroke cylinder.
I know i could just wait till its done and try it, but was wondering what my cycle times might be.
Thanks!
Moose13
   / estimated cycle times (log splitter) #2
My guess, is 12 seconds.
But to calculate, roughly 302 cu. in in the 24" cylinder filled (may be a bit less). There are 1.3 gal of liquid in 302 cu in. 13.6 gpm converts to 0.2266 gal per sec. Divide the 1.3 gal by the 0.2266 gps and get 5.74 seconds to extend. May be faster on the return, so may be closer to 11 seconds total cycle time. The guess was close.
Very nice! Thank You:thumbsup:
I was hoping for somewhere right in there.
Moose13
Thanks Scooby!
   / estimated cycle times (log splitter) #7
A Haldex-Barnes13 gpm pump? Or a knock off 13.6 gpm??
A 13.6 gpm cycle a 4x2x24" at about 10 sec...
I got a "treat" for you!
Online spread sheet...Haldex-Barnes two stage pumps
Spread sheet can be down loaded to your own computer as Excel or OpenOffice file. Then you can edit numbers as you want...keep this link for recovery, if formulas get lost....
Only numbers in the Green cells are subject to change.
Play with pressure setting numbers to see how horse power requirement changes
Pump displacements and max allowed pump speed and pressure, is copied from Haldex-Barnes info PDF file
Note that all flow numbers are based on a 3600rpm pump speed.
Cool!
Yes it is a Haldex 13.6 gpm.
I started fabricating the splitter today i will update with pictures.
   / estimated cycle times (log splitter) #9
formula to figure cylinder velocity is:
Q=VA
Q= flow rate
V= Cylinder Velocity
A= Area of cylinder in square inches
   / estimated cycle times (log splitter) #10
Cool!
Just curious....
I do not know how you got that "13.6"-number??Do you have "some mouth to mouth" information, or some facts that can be backed up, that I have missed. Maybe a discontinued pump model?
Haldex-Barnes pump with nominal flow 13 gpm, flows 13.11 gpm at 3600 rpm.
Math:
displacement on the two pump units are 0.194+0.647=0.841 cui.
Out put flow will then be 0.841 x 3600=3,027.6 cui/min>>3,027.6/231=13.11 gpm
That is the theoretical flow, which will be reduced when internal leakage gets counted into the equation. Volumetric efficiency is not posted in the H&B pdf, can be expected to be between 85-95% with a 300SSU/57cSt viscosity oil and at operating pressure.
Since high flow is at a lower pressure, I would "guesstimate" eff to 95%, and actual high flow would then be about 13.11 x 0.95 = 12.5 gpm....
Not a big deal, but with wrong impression of real flow, it is easy to make a call for a bad pump....
2001 JOHN DEERE 310G BACKHOE (A52705)
2001 JOHN DEERE...
2015 Chevrolet Express 4500 Shuttle Bus (A53422)
2015 Chevrolet...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2014 VOLVO A25G ARTICULATED DUMP TRUCK (A51406)
2014 VOLVO A25G...
Caterpillar 262 B 4 Tires Solid with Rims (A53117)
Caterpillar 262 B...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A53473)
John Deere 5090E...
