Error message on display neutof
   / Error message on display neutof #1
MathewsDXT
John Deere 4320
I was operating my 4320 last night for about an hour. The machine was working great with no problems. It is a power reverser. I stopped and went into reverse and the motor died. The display read "neutof". When I put the shifter into neutral the display message goes away and the hour meter is shown. I can start the engine fine, but it will die when I put it into forward or reverse. Also, I can start the engine, engage the rear PTO, and stand up out of the seat with out the engine dieing. I want to think it has something to do with the seat switch but I am not sure and need so help. My tractor is stranded in the middle of the road and I need to be able to move it. Any sound advice would sure be helpful right now.
   / Error message on display neutof #2
Call your dealer immediately...
I'm going to guess it's your neutral safety switch gone bad. If you have a service manual (or some other TBNer is nice enough to respond), you may be able to locate the switch and test it.
If the tractor is really setting on a road and you can get it in neutral (reverser, gear and range selectors all in neutral), you should be able to tow it if you have a truck or SUV. You will want someone on the tractor to operate the brakes.
BTW, Welcome to TBN...just sorry it's off to a bad start with your 4320...
   / Error message on display neutof #3
Do a google on "error neutof" and you'll find lots of info which should help with your problem. Most info is from previous posts here on TBN. Good luck.
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
1270 (A50490)
1270 (A50490)
2010 Toyota Prius Hybrid Hatchback (A53424)
2010 Toyota Prius...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
