Error codes
   / Error codes #1
Kc8ehd
Hinton Wv
LS XR4040C
New Holland giving error code 3305 , Stop on dash lighting and going into limp mode ... has happen twice , both times going down hill with engine holding tractor back , turn key off and restart it will run fine all day .. any ideal what could cause this ?....thanks in advance for your help
   / Error codes
I got the code description . Just what would it to give this code during engine breaking ?
   / Error codes
Have the complete code list for new holland and others , my question is just what would cause to give this code during engine breaking ? Possibly a loose wire?
   / Error codes #5
Unless someone here has had the same code I'd suspect you'll have to get the answer from a dealer service dept. Sorry I can't help.
2001 Ford F-250 Pickup Truck (A55852)
2001 Ford F-250...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
Heavy Duty D-Ring Shackles (A55852)
Heavy Duty D-Ring...
10' Fork Extensions (A56469)
10' Fork...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
