Error code #74 on 4320.
/ Error code #74 on 4320. #1
AKfish
Super Member
Alaska
JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
Neighbor with a 4320 can't track down either her owner's manual or the problem for a code 74 flashing on start-up.
Says the tractor does everything it's supposed to do - so, she doesn't understand what's wrong...
Any ideas?
Thanks in advance.
AKfish
/ Error code #74 on 4320. #2
Tech manual for 4520 shows ERR 74 as "Display Mode switch is stuck ON".
Pete
/ Error code #74 on 4320. #3
I googled that error code and got the same thing. It said "Lcd display switch is stuck in the on position either play with the switch until the code goes away or have the dealer replace the switch,it should still have warrenty."
Answers very much appreciated. (Wonder if her battery is running down, too?) Sounds like it should be...
AKfish
/ Error code #74 on 4320. #5
Looking at the wiring schematic, the mode switch (S4) has a resistor symbol inside of the block with the switch. The description of the switch under "Display Mode Switch Circuit Operation" (page 256 or so) just says that when the switch is depressed, power is supplied to the ICC. It's not clear what the resistor symbol is for, I'll guess that it's a simple divider which insures that the +battery that goes in comes out as 5V or something. Nothing is said about what the voltage on the open wire (908, gray) that goes to the switch would be when the switch is open. BTW, the battery is on the red wire going into the switch.
The turn signal switch just feeds switched battery into the ICC, no resistors shown. All this might be as simple as what inputs where averrable on the ICC, and perhaps some were 5V input and some were +12 inputs.
The mode switch comes off of the key switch, so if the tractor is off the switch will not draw down the battery.
I would think you could put a meter on the switch and see things change as the switch was toggled to help determine if it's the switch or a wiring problem. I belabor the point about the resistors so that it's very clear that shorting out the switch at the contacts is probably a bad idea, since it would send 12V into the ICC so be careful when making this measurement.
Another "clear as mud" post....:eek:
Pete
76" X 15' BUMPER PULL TRAILER (A63291)
76" X 15' BUMPER...
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
2022 EZ-GO ELITE...
1995 Ford LT9000 Tri-Axle Dump Truck (A61573)
1995 Ford LT9000...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
