Error code 08 on a 3320
   / Error code 08 on a 3320 #12
I also am interested to find a fix to my 3520.
   / Error code 08 on a 3320 #13
Still looking for someone to help me clear the error code 08 on my John Deere 3320. I have put up with it for over a year now and driving me crazy. Thanks if you can help. email at estewart@iowatelecom.net
   / Error code 08 on a 3320 #14
Won't the Deere dealer in Mt Pleasant help you figure out the code problem?
   / Error code 08 on a 3320 #15
They kind of scare you, have you ever been there? Tom is great, but their help is another story. Not only that, I don't want to spend $150 bucks if I can fix it myself.
   / Error code 08 on a 3320 #16
Err 08 Throttle Sensor Voltage signal out-of range or not calibrated. No anti-stall function; Loss of performance.
Calibrate the sensor. Check the sensor and white wire and connections.
Don't have the throttle calibration procedure - but, it's probably the same one that has been posted previously in this thread.
   / Error code 08 on a 3320 #17
Karl2, did you ever find a fix for the Error Code on a 3320. I finally took mine in for repair and a new seal to be put in and they broke something else on the tractor, so won't know for a few weeks. Let me know if you did and what you did. Gene IowaMarine
   / Error code 08 on a 3320 #18
I notice that we have a lot of people on line that want you to think they know a lot about tractors and when you ask if someone can help in fixing an error code, they all tell you to spend your money and take it to the dealer. Do most of you own shares in John Deere? Ha. just checking. Still never found a fix on Error Code 08 on a 3320 JD and I see that a lot of you still have the problem. I gave up and live with it, it goes off after a while. I learned a lesson on here, look first and if no one is trying to help with a question, just go away and come back in a year and if someone has helped someone on a problem, it will be solved or still hanging there. Thanks. I guess I have burnt my bridges or will have to change my name. Thanks for your help.
   / Error code 08 on a 3320 #19
We also have allot of people online that probably couldn't change their own oil, but think they can tackle technical problems without a service manual. Then get irratated when someone doesn't swoop in and solve their problem for them.....
I think the solution is pretty obvious...re calibrate or replace the throttle position sensor, check wiring and connections pertaining to the throttle position sensor. If owners aren't willing to get a repair manual, how can they fix anything???
Did you know that you can put your tractor in a diagnostic mode and view raw sensor data and calibration data on the display? You could probably figure out your problem in a matter of a few minutes.
DEUTZ MARATHON...
48" Skid Steer Pallet Fork Attachment, Asset# 66 (A59076)
48" Skid Steer...
JOHN DEERE 330G SKID LOADER (A58216)
JOHN DEERE 330G...
(APPROX. 11) JOHN DEERE PLANTER FRAMES (A58374)
(APPROX. 11) JOHN...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
DEUTZ MARATHON...
