ERROR CODE 010H
   / ERROR CODE 010H #31
A volt meter will show you if you have a bad battery after charging it up. Just connect it to the battery and hit the starter.if your volts go under 11 volts your battery has an issue. I have a charger that does 2amps, 10amps and a boost of 75amps.
This was me. While my battery was connected it was showing good voltage (even while cranking), but after checking everything and not seeing much of a draw anywhere, I disconnected the battery and it said I only had 9 volts.😄(n)
   / ERROR CODE 010H #32
That is not normal at all.
   / ERROR CODE 010H #33
I have a NOCO 2Amp smart battery maintainer on my 2014 CK30HST tractor and it’s plugged in 24/7 when parked inside the shed. My tractor can sit for several weeks sometimes, but there’s 535 hours on it. The oem battery is 8 years old…and cranks like new, hopefully I didn’t just jinx myself 🤞
   / ERROR CODE 010H #34
View attachment 761269I have a NOCO 2Amp smart battery maintainer on my 2014 CK30HST tractor and it’s plugged in 24/7 when parked inside the shed. My tractor can sit for several weeks sometimes, but there’s 535 hours on it. The oem battery is 8 years old…and cranks like new, hopefully I didn’t
   / ERROR CODE 010H #35
Great idea but you just jinxed yourself.
Hydraulic Stump Grinder (A47477)
Hydraulic Stump...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A55302)
2019 BOBCAT T630...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
24" Bobcat Excavator Bucket (A50775)
24" Bobcat...
John Deere 6059T (A53314)
John Deere 6059T...
MISC PALLET (A55745)
