Erratic Front End Loader
   / Erratic Front End Loader #11
Hi,I have the kl254 loader and when I back drag the bucket won't stay pointed down,it just flattens out,air in the line? or cylinder? how to bleed it?
   / Erratic Front End Loader #12
Found this with the search engine on this site -
Re: Help with loader problem
Run the tractor to warm the fluid. Then dump the bucket fully and hold the control against the stops for 5 seconds. It will make some buzzing or vibrating sound as the relief valve opens --> that's normal. Then curl the bucket up and hold the control for 5 seconds against the stop. Repeat that cycle 3-4 times and it will bleed out all of the air in the cylinder.
This procedure is something I do at startup :)
   / Erratic Front End Loader #13
Hello,thanks for the tip.I tried it and there was no change however,I discovered if I put the bucket down flat and then curl it down and then backdrag it stays in place.maybe thats the way it's supposed to operate.as you can tell,i'm pretty new to this.thank you for your time/help.
   / Erratic Front End Loader #14
:welcome:
You're welcome
2015 Freightliner Bucket Truck (A55973)
2015 Freightliner...
2009 IC School Bus (A55973)
2009 IC School Bus...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
TANK MANIFOLD (A58214)
2012 NISSAN AWD Rogue (A56859)
2012 NISSAN AWD...
2014 WESTERN STAR 4900 SB ROAD TRACTOR (A51406)
2014 WESTERN STAR...
