Ergonomic issue with shuttle shift
   / Ergonomic issue with shuttle shift #1
kpbeddin
Bronze Member
NW South Carolina
Kubota BX 2200 and LS I3030
Has anyone else experienced repetitive motion problems from using the shuttle shifter (common on LS and I'm sure other brands)? I guess I am showing my age, but my left elbow has a constant nagging pain and hurts when I lift anything heavier than drinking cup. All I can attribute the problem to is operation of this shifter as I have been doing a lot of close FEL work clearing some of my property. Any insights/suggestions would be appreciated.
   / Ergonomic issue with shuttle shift #2
I get the same thing once in a while if I'm using my left arm to pull a lot. Like when I'm setting floor joist. I've been told it is common tennis elbow :confused:
Anyway, an elastic tennis elbow thingy found in any drug store helps me a great deal. At least I can pick up my coffee cup :D
It looks like an elastic tube about 5" long. Wear it on the forearm just below the elbow to support the tendons.
Good luck.
   / Ergonomic issue with shuttle shift #3
I agree 100% with Gordon. Just about anything can cause those elbow tendons to act up. Constantly operating a shuttle shift could do it. The only cure is rest. Cold compresses also will relieve some of the inflammation as will NSAID pain relievers like aspirin or ibuprofen. (Note: I am not a doctor, just sharing my experience.)
The "tennis elbow" strap takes the strain off of the tendon and allows it to rest even while you work. It takes three weeks to a month for mine to clear up. Just don't forget to wear it or you have to start the healing process over again.
Most sporting goods stores sell a heavy duty strap. Pharmacies usually have them as well but they seem lighter duty. Expect to pay about $12.
   / Ergonomic issue with shuttle shift #4
Get a Hydrostat.. Seriously.
James K0UA
James K0UA
Funny you should say that, as I thought the same thing, but the money has already been spent. To complicate things (everyone will think I'm a hypochondriac now), but I developed a knot on the tendon of my right foot recently which I wondered if it is from operating the pedal on my BX-2200 (hydrostat) which I use to cut 3 acres every week.
Thanks for the tips guys I will follow your advice, epecially the "rest' part. I plan to start resting in a deer stand soon.
2016 CATERPILLAR 325FL EXCAVATOR (A52705)
2016 CATERPILLAR...
Ford Tractor (A50120)
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53473)
LIKE NEW 2023...
MISC WRENCHES (A53843)
2012 CATERPILLAR 316EL EXCAVATOR (A51406)
2012 CATERPILLAR...
