Eradicating rocks before tilling
   / Eradicating rocks before tilling #1
Red_Ranger
Yanmar SA425
First off, I want to apologize if this post is not in the correct section. I have a farm that I recently purchased and will be looking to do about an acre of food plots on for deer this coming season. To my knowledge, this ground has never been worked and after examining it, I’ve noticed a lot of rock. I have a 25hp tractor to work with, my question is what would be the best way to find and get rid of rocks prior to running a tiller through.
   / Eradicating rocks before tilling #2
Running a tiller through it will find the rocks.
What I would do with mine (similar setup to yours) is just make some passes with the tiller, then go around and put rocks in the loader and create a rock pile somewhere to dump them.
After you think you have all if the rocks removed, it’ll rain, and you’ll find that hundreds of more rocks have magically appeared……
The problem is these are big rocks and I don’t want to damage the tiller
   / Eradicating rocks before tilling #4
The rocks won’t damage the tiller. It will bang and bounce around alot. Presumably it has a slip clutch.
I never broke or bent anything on my tiller, and I worked it hard. They are built tough.
   / Eradicating rocks before tilling #5
Plow it then disk it. Otherwise do what Seville recommended take a light pass check for rocks dig them out.
With the tiller you can tell you've hit a rock sometimes before you unearth it. if you have another person helping you you can point it out as you're doing it.
Hitting a rock once with a tiller sometimes can't be avoided hitting it twice can be.
I don't like to hit them either but as was said those tillers are pretty tough. A big enough Rock will jam and share a pin or slip clutch or just kill your tractor.
If it kills the tractor, my advice would be get the tractor started, with the PTO off, quickly since it has been running hard. Just let it idle as you dig the rock out
   / Eradicating rocks before tilling #6
I've plowed, harrowed, disced, and tilled. Picked rocks and done it all over again. I still have rocks every year... some big enough to trip the bottom on the plow.
If your climate has frost there will always be rocks working their way up. The potato fields north of me have been worked for 150 years yet they still are picking rocks.
I usually pick every spring, disc it and pick rocks again. Then as I'm tilling I stop and pick the bigger ones which work their way up through.
   / Eradicating rocks before tilling #7
Do you have frost? New rocks will grow every spring. You will find them by tilling. Pick them by hand. Next spring a new crop will grow.
   / Eradicating rocks before tilling #8
There are rocks and then there are ROCKs. I can just go straight in and use the tiller on my yard, my son's yard not so much.
His yard is nothing but rocks all sizes and I wouldn't let him till without plowing and disking and then see if the tiller needs to be used.
While a tiller can handle a few rocks, I have my limits of what I'll let my tiller do.
   / Eradicating rocks before tilling #9
Yanmar SA 425 is an 1,830 pound, under 25-horsepower tractor.
Not enough tractor weight, not enough power to pull a Disk Harrow of effective weight.
I suggest a Middlebuster, AKA Potato Plow, with replaceable plow blades. Ample for a one (1) acre food plot. Relatively cheap, low draft resistance (low traction requirement), short operator learning curve.
Tarter produces 'CountyLine' brand implements as private labels for Tractor Supply Company.
MORE ON YOUTUBE:
   / Eradicating rocks before tilling #10
How big are the rocks?
There are some threads here discussing skeleton rock buckets you may want to read.
Skid loaders can be rented in some areas with attachments designed to remove rock.
TOYOTA 8FGCU30 FORKLIFT (A50854)
TOYOTA 8FGCU30...
1043 (A50459)
1043 (A50459)
2020 Freightliner Cascadia 126 T/A Sleeper Cab Truck Tractor (A49461)
2020 Freightliner...
2012 Ford F-250 Ext. Cab Service Truck (A50323)
2012 Ford F-250...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
3014 (A50657)
3014 (A50657)
