Eradicating bamboo
/ Eradicating bamboo #1
Pilot
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
A friend has bamboo around his deck. It spreads very aggresively and he can't seem to get rid of it. Has tried Roundup to no avail. Don't know what time of year he used the Roundup or if he used a surfactant.
Anyway, how do you get rid of bamboo?
/ Eradicating bamboo #3
Why get rid of it, harvest it, sell it. Have a local zoo?
/ Eradicating bamboo #5
just tell my wife it is a very exotic plant and is really neat- it will wilt and die with in a week!
/ Eradicating bamboo #6
How big an area? In the past when I had small areas that brush would keep coming back I would cut it off at ground level. Cover with heavy carpet and bury with 8" bark mulch. If it's a big area, dig it out with your tractor.
/ Eradicating bamboo #7
I found out (the hard way) the reason Round Up doesn't work.
Round Up is actually a fertilizer...a zery hot fertilizer...and Bamboo thrives on it.
Only way to get rid of it is as HappyCPE said. Dig it up - and any bits of root that break off will come back double the next year.
/ Eradicating bamboo #8
Digging, cutting down, and lots of persistence are the only things I can suggest. If he would be satisfied with containing it, he can try driving galvanized roof flashing down around the area. That shold effectively stop the roots from spreading. I've seen that used on bamboo and river cane patches that are maintained as ornamentals.
/ Eradicating bamboo #9
RHughes, the only thing wrong with galvanized is that it will eventually rust. Bamboo lives 100 years or more and the galvanized time horizon just isn't that long. The best sheetmetal barrier would be aluminum. Al or plastic is usually what bamboo nurseries recommend. Either that, or plant a "clumping" or non-spreading variety.
/ Eradicating bamboo #10
Go to Forestry supply .com and look for Garlon. It's a product used to control unwanted growth in forests. It will kill a tree up to 8" in diameter if sprayed around the bottom 18" of the trunk. I've never tried it on bamboo but it works very well on beech and striped maple.
Thanks for the ideas, all of you. He doesn't have a tractor & he is too far for me to drive my tractor there. It probably covers an area about 20' X 20', but there is a wood walkway thru the middle of it & he doesn't want to rip that out, although the damnboo is growing up between the boards.
I passed on your input; we'll see what he does & what works.
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
1997 LEDWELL 48FT DOVETAIL TRAILER (A67714)
1997 LEDWELL 48FT...
2015 PETERBILT 320  T/A GARBAGE TRUCK (A66091)
2015 PETERBILT 320...
2016 John Deere 6155R (A64119)
2016 John Deere...
