Equipment Shed Project
   / Equipment Shed Project #1
voodoo
N. Ireland (UK)
Iseki TE 4270
Well, I just received in the mail today, Planning permission for extension to the house and for a new shed. Guess which one is being built first /forums/images/graemlins/wink.gif I've already started the footings in anticipation of the approval. Glad it came through.
Shed is going to be a 30' x 20'ft lightweight steel box section frame with profiled metal cladding panels for roof and walls. Supplied and installed in kit form from manufacturer. All I have to do is install the foundation base and walls.
It can be installed directly onto a concrete raft slab, but due to the grade I have to contend with, this was not an option. Elected instead to put in a proper foundation, build up base walls and cast floor slab on hardcore fill.
I have some drawings of the shed, pictures from the manufacturers brochure and some early excavation pics of the project in site.
Anyone want to see /forums/images/graemlins/confused.gif
Design plan for shed
Perspective view
Pic from manufacturers brochure
Pic 2
Start on site. Pic 1
Cliff,
Not as yet. I don't intend using this as a workshop, although you never know.
I am going to bring heavy armoured cable from existing garage underground to a distribution panel. From there I think it will be a metal trunking at mid height round 4 sides with socket points dropped down as required. This will allow flexibility and welding circuit if required.
Lighting will probably be twin tube flourescent, although I am also looking into low bay sodium units. Anyone have any knowledge of these?
Nigel
Work is taking me away from computer for the next 4-5 days.
/forums/images/graemlins/mad.gif I can feel the withdrawal symptoms already. Both on tractor and on TBN.
I'll try and post some more pics and answer any replys on my return.
Nigel
Some updated pics as promised.
I have used pixresizer for better definition.
Pic 1
View from rear yard at garage. Base excavated to grade.
8ft Fork Extensions (A51691)
8ft Fork...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
2017 Ford Explorer SUV (A51694)
2017 Ford Explorer...
23222 (A50323)
23222 (A50323)
(4) 250/80-15 Solid Forklift Tires (A52384)
(4) 250/80-15...
