Epoxy Metal to Plastic Recommendations
   / Epoxy Metal to Plastic Recommendations #31
Hi all!
Sorry to bring back the dead, but if I would like to epoxy plexiglass to aluminum will the recomendations in this thread work?
   / Epoxy Metal to Plastic Recommendations #32
You might try PC7.. I see displays of it in hardware stores. Usually a bottle cap is glued to a penny, that is then glued halfway into a blob of epoxy stuck on a sodaa bottle.. that is epoxeyed to a brick or something like that.
For what it is worth.. I haz jb-welded a small brass hinge to a piece of plexiglass at work to make a swing open cover for some electronic gear. It's holding so far. ( You might try to add a few ridges or rough up the p-glass where you epoxy it..
Soundguy
   / Epoxy Metal to Plastic Recommendations #33
You have to look hard, for all stores do not carry it, but there is a type of epoxy made specifically for plastics. It goes by the name of Plastic Mender or Plastic Bond. I think 3M has a product also. It is a two-part compound that chemically reacts like epoxy, but usually smells much worse. Also, usually the set is pretty short, like 5 to 10 minutes. It bounds plastic to plastic very well and plastic to metal. It remains a little more flexible than most epoxies, which seems to make it even more suitable for plastic. If a store carries it, it will be with the epoxies. I've used JB weld with some success, but it does not compare to the products suited specifically for plastic.
   / Epoxy Metal to Plastic Recommendations #34
pc-7 will most likely work but it does have a long dry time.(24 hours) This could be good or bad depending on if you want to use it soon. But if it is mix right it is some strong stuff
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2018 FREIGHTLINER...
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
2022 John Deere 5065E MFWD Tractor (A53485)
2022 John Deere...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
