epdm hose
/ epdm hose #1
ppea
1056xl,grillo g 110
I replace a suction hose from my hydraulic pump on my tractor and after that i saw it's a epdm multipurpose hose and it's not compatible with oil. How long will it take to start degrading and cause problems ?
/ epdm hose #2
You need to look for a replacement and not leave it until you have problems as it will deteriorate and could cause problems with your hydraulics. It will start to get gummy where the oil runs.
/ epdm hose
It's all the time oil inside hose and it's 90cm long.I thing maybe last one year or two.
/ epdm hose #5
It won't last long, but the inside of the hose could start shedding material and end up clogging or damaging hydraulic components.
Change it as soon as possible!
/ epdm hose
I check and the previous hose was DIN 73411 that means it was epdm too.I thing it was on tractor a few years and has no sign of wear in interior.
/ epdm hose #7
EPDM is more weather resistant that nitrile and repels water better but depending on type of EPDM compound it may or may not be hydraulic oil resistant.
DIN 73411 is meant for antifreeze and is intended for radiator coolant hose.
/ epdm hose #8
Well, it's your tractor.
/ epdm hose
I found a semperit fmo hose (seems to have right spec) and i wil change tomorrow.In the future i have to change 2 very pieces of hose but didn't find the correct diameter.Until then i use a piece of sicilone and one piece is for radiator.This 2 pieces is only for conecting the filter and the hydraulic pump.
(10) 24' Free Standing Panels (A64912)
(10) 24' Free...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2003 (INOPERABLE) CHEVROLET C7500 (A67714)
2003 (INOPERABLE)...
CAT D6 Limb Sweeps (A68134)
CAT D6 Limb Sweeps...
