EP80w-90 gear oil for bush hog
   / EP80w-90 gear oil for bush hog #1
botemout
Upstate NY
1957 Ford 860
So the manual for my SQ720 says that I should use EP80w-90 gear oil but my auto parts store (all that's open tonight) has SAE 80w90 gear oil.
Are these basically the same?
Thanks
   / EP80w-90 gear oil for bush hog #2
It's the same I think the EP is a European thing
   / EP80w-90 gear oil for bush hog #4
Thanks
EP refers to Extreme Pressure additives added to high quality gear lubes. Most major brands will have this package. Usually it is prominently announced on the packaging.
Nothing to do with Europe.
Hmm, I went to the local Advance Auto and bought SAE 80w-90. It was about $11/gallon. Hope that does the trick.
   / EP80w-90 gear oil for bush hog #6
just about any gl4/5 gear oil would likely work.
soundguy
   / EP80w-90 gear oil for bush hog #7
100% correct. EP just means extreme pressure and any quality 80W90 gear oil will have this. The Auto Zone stuff will be fine.
Chris
John Dozer JD650 (A51691)
John Dozer JD650...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
1273 (A50490)
1273 (A50490)
Plasmarc PM150 Plasma Cutter (A54811)
Plasmarc PM150...
UNUSED LANDHONOR LHR-G209 ANCHOR SHACKLES (A54757)
UNUSED LANDHONOR...
