Entrance Height
   / Entrance Height #11
TNhobbyfarmer said:
...with two vertical poles and a horizontal pole mounted on top of the side poles.
What are you going to use for the poles?
Metal pipe comes in differnt lengths with 20 feet being about the shortest that I'm aware of. I buy Four inch Galvanized heavy wall pipe for under $100 each from a fence supplier. I don't think you can get that price, but it's worth a try.
I was talking to a fence guy the other day and he pointed out that using used oil pipe fence is risky because the succer rods wear the pipe out from the inside and you never know how thick the walls are. You might get a good pipe, or you might have one with areas that are paper thin. Unless you cut it or weld on it, you won't know until if fails on you.
A 20 foot joint with four feet in the ground will give you a very impressive 16 foot height!!!! Four inch is strong enough to not bend on you, but bigger would sure have more impact on how impressive it looks. Of course, with 16 feet height, you could also hang something from the top with amost 2 feet to create a name or design and still have over 14 feet of clearance!!!!!
Eddie
   / Entrance Height #12
Dale_Alan said:
Make it high enough to get a backhoe or dozer on a trailer into the property.
Firetrucks? Trust me by the time they get out there it will mostly be gone and if they put it out and save part of it the insurance company will rebuild around it. I've been there and done that, you want it down on the slab.
I understand in some rural areas response time can be long. In many area's though, you will get a BLS(EMT), or sometimes an ALS(Paramedic) Engine on scene before a medic unit arrives. I wouldn't want an already prolonged response to a medical emergency to take even longer due to access limitations.
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
2015 International DuraStar 4300 Johnston VT651 Street Sweeper Truck (A55788)
2015 International...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
UNUSED LANDHONOR LDH-FPR36 - 36" FIRE PIT RING (A54757)
UNUSED LANDHONOR...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
