Enough is enough!
   / Enough is enough! #11
A few years ago, a friend dropped by my house (people do NOT just drop by where I live...) He had a 300 gallon fuel tank in the back of his truck. He said he'd bought two in an auction, this was my half the deal. (what deal? /forums/images/graemlins/confused.gif) I paid the man his $300.00 and it has just sat there.
My new tractor uses enough diesel, and is not too convenient to fill. So I called the bulk fuel guy, and I can save a pretty good chunk by getting it from him.
Sure was a great idea I had getting that tank...
   / Enough is enough! #12
RaT:
That's about what the 250 gallon bulk tank I made cost. I used a discarded heating oil tank and added a Great Plains transfer pump. I have the petro distributor fill it when they fill our 5,000 gallon tank on the main farm.
   / Enough is enough! #14
RaT:
Yeah.....But my fuel tank isn't an E4od either. /forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif
   / Enough is enough!
If I could easily replace the E4 with a manual and do it economically I would be tempted to do it. Did I mention by turning the handle on my 30 gallon gas caddy with the 10 X 2.75 semi pnuematic tires and powder coated red paint job the opposite way it sucks fuel. How about that Daryl! /forums/images/graemlins/laugh.gifRat...
   / Enough is enough! #16
That price is a fraction of the cost of maintaining a hosed-up back. Betwen chiro and meds and PT, I spend well over a grand a year. Insurance covers most of it,..But
Be good to your back!
As for indulgance, I have a BX2200 and less than 1 acre of land.... AND I want a bigger tractor /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
   / Enough is enough! #17
RaT:
You can't, however. You'd need a new bell housing and the tail shaft is completely different. Besides, you'd have to hang a clutch pedal and you'd have to go with the dreaded hydraulic actuator for the clutch. As far as my 250# tank, I could put it on wheels and put a tongue on it but I have a diamond plate aluminum 100# tank that goes in the back of my 350 Ford that works in the field. It has an electric pump too!!!!!! I do like your gas caddy, however, it would work good for filling my riding lawnmower, weed wackers and other small gasoline powered tools. I think I'm going to order one. At least I won't put diesel in my lawnmower anymore.
   / Enough is enough! #19
RaT, I feel your pain. I have a JD 4410 that I have to climb all over to get the fuel in as well. I just use a REALLY BIG filter funnel which seems to catch any spills. You would think they would design the dad gum busted thing better than that! I have a 30 gallon drum I am going to use for refueling with a hand pump and hose in the future.
   / Enough is enough! #20
I guess I don't know enough about how hand turned pumps work, but one of the reasons I went with a gravity setup is because I tried to picture myself reaching down and turning the crank while reaching up and holding the nozzle in the filler, and at the same time getting to where I could see when it was close to full. (The other reason is because I'm too cheap to buy an electric pump.)
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
