Engine wont turn over. LS XR4046.
   / Engine wont turn over. LS XR4046. #1
Barrypettit
LS XR4046
My tractor went dead while in idle yesterday. Now the glow plug light wont come on and will not turn over. I checked all fuses and they are good. Any suggestions?
   / Engine wont turn over. LS XR4046. #2
Have you verified you have a good battery by a load test?
   / Engine wont turn over. LS XR4046. #3
I vote for water in the fuel/filter separator or a bad ground/shorted wire.
   / Engine wont turn over. LS XR4046. #5
Yes i checked the battery and it tested good.
Check your battery connections, if those are good continue checking connections down the circuit. It sounds like you just have a dirty terminal someplace. (presuming that you have an electric fuel pump.)
2009 IC School Bus (A55973)
2009 IC School Bus...
25 TANDEM DUAL GOOSENECK TRAILER (A58214)
25 TANDEM DUAL...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
Deere 335P (A53317)
Deere 335P (A53317)
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52707)
(INOP) 2016...
