Engine won't hold rpms
   / Engine won't hold rpms #1
adegiulio
Red Hook NY
JD 4310
Interesting and annoying little problem here. I didnt use my tractor (4310) much over the winter. I've been using it a lot in the past few months, and I've noticed that as I'm using it, the rpms slowly creep lower, requiring me to constantly throttle up. It seems to occur faster if I'm doing "heavier" work.
Any ideas?
Thank you
   / Engine won't hold rpms #2
Just need to tighten the friction disc. There are threads here that will give you more info.
Doesn't take much, and I only had to do it once.
   / Engine won't hold rpms #4
My 2210 did the same thing, had to 'tighten' the throttle a bit and it's been fine ever since.
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
2014 Peterbilt National Crane Series 900A 26 Ton Tri-Axle Crane Truck (A52377)
2014 Peterbilt...
2005 Ford F-750 Truck, VIN # 3FRXF75R05V113199 (A53422)
2005 Ford F-750...
UNUSED DIGGIT 10D-10 DRAWER WORK BENCH (A54757)
UNUSED DIGGIT...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
2430 (A51248)
2430 (A51248)
