Engine trying to shut down.
   / Engine trying to shut down. #1
Lazy
Platinum Member
Missouri
ford 1920 w/fel and bh, case 470, allis chalmers B 1937, JD 450 track loader, Case vac, 3 cub cadets ford lgt 125, Kubota 2230/60 inch mower.1948 farmall cub 1953 farmall cub
Engine seems like it is starving for fuel when going down hill even with full tank. Replaced fuel and air filters, no help?
Any ideas?
   / Engine trying to shut down. #2
Check the pressure on the lift pump.
Forgot to mention the tractor is a kubota bx2230
   / Engine trying to shut down. #5
Is the lift pump the fuel pump?
Disconnect the fuel line at the lift pump (it's the pump ahead of the injector pump in most fuel systems). Crank the engine like you are starting it and you should see a CONTINUOS gush of fuel from the fuel line. If it dribbles or is intermittent work your way back to the tank and find the restriction. The usual culprits are a blocked or pinched fuel line, a plugged filter head, or a clogged tank outlet. Some lift pumps have a screen on the inlet side that can clog.
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
1000 Gallon Concrete Fuel Tank (A50774)
1000 Gallon...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
