Engine trouble
   / Engine trouble #1
johndock
I have a '70s vintage Cub Cadet 1000 that I've been using since last summer for mowing. It ran fine until recently and now it bogs down and stalls out when I run it up a grade. I thought it was the fuel filter but it turns out there isn't one. Then I thought bad gas. I drained some gas from the fuel line and it looked OK, but I drained the entire tank and added fresh gas from another source. No improvement. Could I have crud in the fuel intake to the carb or is there another possibility?
Any suggestions would be appreciated.
   / Engine trouble #2
I would install an in line filter since you say there is none. I would disassemble the carb and clean it. Change spark plug(s)
   / Engine trouble #3
Could also be points and condenser. I recall once a buddy of mine at college had an old Chevy LUV 4X4. It ran great until you put a load on it and then it would just putter out and have no power. We pulled our hair out and finally changed the points, cap, and condenser after replacing about everything else (wires, filters, plugs). That was the ticket. Ran great after that.
Chris
   / Engine trouble
Thanks. I'll check those possibilities this weekend.
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A53473)
2022 NEW HOLLAND...
2013 Chevrolet Silverado 1500 Pickup Truck (A53117)
2013 Chevrolet...
2004 FREIGHTLINER FL70 FLATBED W/TANK & DITCH WITCH MIXER (A53843)
2004 FREIGHTLINER...
2012 CHANDLER 130 BBL STEEL VACUUM TRAILER (A53843)
2012 CHANDLER 130...
