Engine swap on toro Zero Turn.
/ Engine swap on toro Zero Turn. #1
lightning2003sb
MO, USA
Zetor 5245
I have a 2007 toro 50" zero turn. It came equipped from the factory with a 21 horse single cylinder Kohler courage engine. Well the Kohler engine had a cracked block so I chucked it in the scrap heap. I found a Used Briggs and Stratton V twin Intek on eBay and I bought it. Problem is, It didn't come with a voltage regulator. Also, I unknowingly cut off and threw away the diode coming off of the alternator. My Question is, does anyone on here know what Voltage regulator and diode i need for my engine? The model number is 407777-0124-E1. Thanks in advance for any advice.
/ Engine swap on toro Zero Turn. #2
I did something similar and have the same engine. Have you found out the necessary part numbers? I think I need an alternator. A new battery dies after about an hour of use. Thanks.
/ Engine swap on toro Zero Turn. #3
briggsandstratton.com has Illustrated parts list available.
NEW Wolverine SP-15-84W Snow Blade (A62679)
NEW Wolverine...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
2008 Mercury Mariner (A62679)
2008 Mercury...
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
Landhonor 24" Semi-Automatic Tire Changer (A62679)
Landhonor 24"...
2023 Case TV450B (A62177)
2023 Case TV450B...
