Engine swap on toro Zero Turn.
   / Engine swap on toro Zero Turn. #1
lightning2003sb
MO, USA
Zetor 5245
I have a 2007 toro 50" zero turn. It came equipped from the factory with a 21 horse single cylinder Kohler courage engine. Well the Kohler engine had a cracked block so I chucked it in the scrap heap. I found a Used Briggs and Stratton V twin Intek on eBay and I bought it. Problem is, It didn't come with a voltage regulator. Also, I unknowingly cut off and threw away the diode coming off of the alternator. My Question is, does anyone on here know what Voltage regulator and diode i need for my engine? The model number is 407777-0124-E1. Thanks in advance for any advice.
   / Engine swap on toro Zero Turn. #2
I did something similar and have the same engine. Have you found out the necessary part numbers? I think I need an alternator. A new battery dies after about an hour of use. Thanks.
   / Engine swap on toro Zero Turn. #3
briggsandstratton.com has Illustrated parts list available.
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A54607)
2013 KENWORTH T680...
Advance SC750 28in Floor Scrubber (A53421)
Advance SC750 28in...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
