engine sputtering?
/ engine sputtering? #1
kdlklm
Saskatchewan, Canada
Kubota BX1830
I was doing some tilling on a steep incline going up and the engine would start to sputter and it wouldn't stop until I leveled it out, and it still took a couple seconds. It seems to be doing it consistently, I only tried three times but it sounded so badly I didn't want to push it. If I am on an incline sideways it's fine. It's a BX 1830 with 8 hours on it. Has anyone else experience this.
/ engine sputtering? #5
It sounds to me like your not getting fuel at that angle. I don't know you did not state how much fuel was in the tank.
/ engine sputtering? #6
/ engine sputtering? #7
How much fuel is in the tank? Does the BX1830 have a gravity fuel system? My F2400 has a gravity feed and I have the same symptoms (in my case going up steep hills in reverse) - i.e. when the fuel level in the tank is lower than the fuel injector feed. It sounds like it is starving for fuel. /forums/images/graemlins/smile.gif
/ engine sputtering? #8
/ engine sputtering? #9
Well thats the other thing. The sending unit is on the opposite side of the tank from where the filler cap is. If the angle is really bad I'd expect you might be out of fuel also. Try filling the tank to full and go out on the steepest slope you got and till. If it runs mint you know it's the fuel.
/ engine sputtering? #10
/ engine sputtering? #11
My little tractor with gravity feed always sputters just before I check the tank bottom for debris. /forums/images/graemlins/grin.gif
Egon /forums/images/graemlins/grin.gif
/ engine sputtering? #12
/ engine sputtering? #13
This is probably stating the obvious, but I'll say it anyway. When I am on a steep incline and the engine sputters, it is because the operator safety feature under the seat isn't getting enough pressure from my weight--I tend to lean forward, so the engine starts to cut out, and then goes, starts to cut out, then goes, etc. Same thing happens if I am going over alot of bumps too fast, as I bounce off the seat, the engine starts to cut out.
/ engine sputtering? #14
it seems to have been the fuel level, it only had a half a tank. After I filled it, it stopped doing it.
1996 Vermeer V-3550 Ride-On Trencher (A61572)
1996 Vermeer...
2019 CRUISE CAR INC ENCLOSED UTILITY CARGO CAR (A59912)
2019 CRUISE CAR...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
46" X 51" TRUCK BED SEAT PLATFORM (A64280)
46" X 51" TRUCK...
2017 Ford F-250 4x4 Crew Cab Medical Service Truck (A61573)
2017 Ford F-250...
1980 FRUEHAUF 45' T/A FLATBED TRAILER (A59911)
1980 FRUEHAUF 45'...
