Engine sputtering...What's going on?
/ Engine sputtering...What's going on? #41
Harry c said:
Not necessarily. Sometimes the rubber fuel line can get sucked shut if there is just a small amount of vacuum. Happens most often where the line makes a bend.
That's why i much prefer hard fuel lines.
soundguy
/ Engine sputtering...What's going on? #42
Tommy V said:
It is very easy to miss the slight hissing sound when the cap is removed, especially if you are not looking, or specifically listening, for it. It doesn't take much of a vacuum to overcome gravity which is the way fuel gets to the pump.
True.. I guess.. though those are things I usually look for on my old gassers.. though can't say i do on my diesels.. ( even though they have a vented cap that has a rattle ball in them.. etc. ) Guess a lift pump might help.. however.. in the end.. that would just bandaid the issue if it is indeed a tank vent issue.
would be great if that's all it is...
Next question.. does that tank have a built in vent.. or is the cap vented?
soundguy
/ Engine sputtering...What's going on? #43
The cap is vented.
My old Wheelhorse 856 had a problem w/the gas cap vent being plugged once. Symptoms were surprisingly similar to this, and of course the 856 was a gasser. Gravity flow to the fuel pump then pressurized to the carb.
Was able to tell by just simply openning the cap at WOT and the problem ceased. Cleaned the cap out and it's worked great for the lst 15 yrs :D
It would be great if thats the fix and at this point he's just about alleviated all the other common fixes.
We'll see.....
So, I got home last night and took the fuel cap off and blew through it from the top. I couldn't hear any restrctions and air flowed through without an impedament. Today I fired her up and drove out of the garage and around the yard to the back. I had the cap on a little loose and decided I would tighten it up. After a bit of a warm up she hesitated ever so slightly but only once, like a car misses a cylinder. I decided I would do some backhoe work as that is usually the tell tale truth. I began to lengthen the ditch I am digging for spring runoff on a low spot in my back yard and must have gone on for a good 30 minutes until the evidence returned. However, this time only slightlty and with much longer durations between the sputtering. I am now convinced it is water and is working itself out. I just see no other reason why it behaves the way it is. Go figure.:confused:
/ Engine sputtering...What's going on? #45
I am not so sure water will cause these type of symptoms.
I have read articles in which researchers are blending very large amounts of water with diesel fuel for emission purposes and the engines apparently run OK.
In the winter time, it's another story. Frozen water is a whole different animal, but apparently diesels can swallow a lot of water without problems and at the same time lower emissions.
http://www.energy.wsu.edu/documents/renewables/PuriNoxl.pdf
/ Engine sputtering...What's going on? #46
That site refers to emulsions of diesel, water & surfactants. Normally, oil & water don't mix, and just a little water in a BX fuel filter will prevent the diesel fuel from passing through the filter, causing the symtoms described. Been there - replace BOTH filters & make sure you have no leaks or collapsed hoses.
/ Engine sputtering...What's going on? #47
a little note about your electronic fuel (transfer) pumps. Just because they are making noise does not mean they are doing anything and that goes for orange, blue, green, and red tractors. If you suspect yours has a problem go to your local parts store and buy a transfer pump for a 95 chevy 6.5 diesel, 35 bucks with a lifetime warranty. The flow and pressure is the same and its a little bit more heavy duty than the ones we get on our tractors. As a diesel tech for years i cant count the number of transfer pumps i have replaced, alot of them made lots of noise but no flow, or would work then quit then work then quit. My dads 455 had one that the 12 volt supply wire had broken inside the insualtion that was fun to find.
On the subject of vented caps, i once had a old 6.5 in my stall that the customer had put a fuel cap on off of an old car in his junk yard, the fuel tank looked like it was imploded. crazy stuff !!!
workinallthetime said:
a little note about your electronic fuel (transfer) pumps. Just because they are making noise does not mean they are doing anything and that goes for orange, blue, green, and red tractors... buy a transfer pump for a 95 chevy 6.5 diesel, 35 bucks with a lifetime warranty. The flow and pressure is the same and its a little bit more heavy duty than the ones we get on our tractors...a fuel cap on off of an old car in his junk yard, the fuel tank looked like it was imploded. crazy stuff !!!
Thats interesting. The pump sounds different than it used to in a way that is hard to describe. At the same time, I am getting more and more convinced it is water. Due to the irregular shape of the fuel tank, I drove one side of the rear wheels up on a log to siphon out the fuel, but may have missed some. That said, it is %100 better and once this fuel is burned, I will expect it should pretty much eliminate itself. Albeit, I am not out of the water yet :mad: and changing the fuel pump was the next thing on my list. If it gets worse, especially on this tank, I must assume the transfer pump.
/ Engine sputtering...What's going on? #49
perhaps something to prevent future problems would be to install a water seperator, the filter design on my b3030 has that ability where the bx models do not from what i have seen. mount it to the frame and go, should not take more than 50 bucks and 30 minutes or so.
Space would be the issue. I saw a water seperator at my local auto surplus, but was quite large. Maybe the 3030 could be retrofitted to somewhere under the hood of the BX.
/ Engine sputtering...What's going on? #51
Where did you buy the fuel? I would guess the Lockport Petro Canada?
If you live along #9, I think I saw your tractor out in the yard on Sunday!
Blk88GT said:
Where did you buy the fuel? I would guess the Lockport Petro Canada?!
No, I take the fuel out of my truck since its billed back to me, anyway. Its easier but it means it could be from anywhere. At the time this started, although I cannot recall, I was questionable of the integrity of the source.
I was out on Sunday digging a shallow trench for spring runoff but I live on a crossroad between #9 and #8. Where are you at?
Just to keep all concerned in the loop, it simply cleared itself up, so it definitely was water. At the very end if you went sideways on a steep incline it would sputter a little and it would be the last of the water sitting in the bottom of the fuel filter. I could only make it do that about three times and it stopped completely.
Thanks for all the replies, suggestions! If you guys would just pass the hat and reimburse me for the fuel filters, pumps, air filters, various *suggested* fuel conditioners (none of which had any effect) a variety of fuel brands...oh, and my labor rate is $88 per hour...so....:rolleyes: :p :rolleyes:
/ Engine sputtering...What's going on? #55
If you had water in the fuel, the fuel filters NEEDED to be changed anyway.
Soundguy
/ Engine sputtering...What's going on? #56
Soundguy said:
If that is the issue, and it is drawing enough vacume to starve the lift pump/ injector pump.. then when you opened the tank to add the dewaterer, or remove the fuel filter.. you should have heard a whoosh and/ or gurgling.. etc... should have been very obvious.
Soundguy
True if done promptly after the problem exhibits.
BX2230_Lockport:
Ill agree that a plugged breather is an attractive possibility. The problem with that assumption tho, is that most pumps once primed will cause significant problems to large flat sided containers like fuel tanks if the breather is so restricted as to stop flow. I have seen tanks crinkle in such a circumstance. Gravity feed to a carburetor, common on motorcycles, is much more sensistive to FREE breathing than is pumped supply. I think that you have either a suction air leak or filter restriction. I have encountered the filter restriction on my BX1500 with the exact symptoms you describe. Filter restriction is self generating in that once restriction starts the pleating of the filter begins to close. This decreases the filters area and increases restriction more -- a chain reaction. When you encounter a load the increased fuel demand closes the pleats and the engine starves. My filters were very sensitive to water. It wets the paper and impedes fuel flow. Its pretty easy to get one wet, but very difficult to dry it. I have gone to a screen element in place of the second of the two paper filters, and Im planning to go up to a larger paper filter to further desensitize the water problem, but until then I am being extra careful about water.
larry
/ Engine sputtering...What's going on? #57
I think it will come back! Missing only under load is a sure sign of fuel starvation, not water. If it were water it wouldn't matter if it were loaded or not, it would sputter constantly, especially at idle.
Since it only sputters under load it is a clear indicator the the engine's fuel demand/requirements go above what it is able to get. From there you just have to figure out why it isn't getting enough fuel, fast enough. It could be anything in the fuel system, from the tank outlet to something in the injection pump itself.
Someone dropped a piece of plastic wrap about 2" x 3" in my tractor's tank before I got it, but it worked just fine for a long time. But one day, it shifted and suddenly it wouldn't run correctly. I traced it back to the tank, and even after I took the petcock off the bottom of the tank the fuel just dribbled out. A little probing with a thin wire with a hook, and suddenly a corner came down. I pulled on it, and then the fuel shot out! Has worked fine ever since.
/ Engine sputtering...What's going on? #58
Just a few thoughts...
If you drain the tank, drain it through the petcock. Most tanks are designed to fully drain if on level ground. This would also give you an idea of the flow.
Watch where to check for "sucking air". Since you have an electric lift pump, it only sucks on the tank side, the other side is pressure...usually the filters are on the pressure side. The lift pump is probably somewhere under 10psi, so you might see a leak. If the filters are on the pressure side I don't see how the pleats could be sucked closed?
My 26hp L only uses a half gallon an hour at load and is only a gravity feed, just a trickle from the tank hose. So fuel usage isn't really that high.
It's a tough call on the actual problem, one of these things you do a bunch of stuff, then it starts working and you don't know what it was. It also sounds like an air problem. I ran mine out of diesel once and it took several tries to get it all out. I was surprised at this.
For the water I had one of these laying around.
Good Luck,
Rob
/ Engine sputtering...What's going on? #59
Rob
Its a relative thing. Filters are made to flow from outside to inside. This tends to close the pleating during flow. A filter that has become somewhat plugged by debris or by absorbing water finally reaches a critical pressure difference across it that willclose the pleats. At that point the lurking problem becomes real real fast.
larry
Some points are being overlooked, here. Although it would sputter under load, it was never consistent. In fact it was bad when it first started but got progressively better while still a significant burden. Also, it has done it at idle but only once.
The BX doesn't have a petcock. There are fuel filters on both side of the pump. The cap was never plugged because the sputtering was intermittent (I never did open it immediately after shutting down) but when I blew through the cap there was free air flow without obstruction.
I was Hoeing again today and it is fine. I really think it was water. Water in the bottom of the filters that was originally on the tank and as it depleted ended up as small quantities sitting in the bottom of the filters. It is remotely possible there is a blockage in the tank, but countering that to some degree is that when stationary, using the BH, it evades me how that blockage would get out of the stream. There is no counter force happening.
