Engine speed
/ Engine speed #1
Hinomotoman
Western NC
LS R3039, Hinomoto E2604, Hinomoto N239, Case IH 1140, White Field Boss 31
Suddenly after about 15 minutes of use, my engine speed drops to idle and then tries to go back up but stays mostly on the low end. Any ideas what may cause this? It's a K3M engine.
/ Engine speed #2
Sounds like the old fuel problem. If you are running biodiesel then it could be an algae buildup. It could also be water in the fuel or dirt or air in the fuel lines.
/ Engine speed
That's what I was thinking but my other four tractors are using the same fuel and run just fine.
/ Engine speed #4
Different fuel systems will tolerate water & dirt better than others.. so saying THAT doesn't "hold water" so to speak..
Change the filters & "back-blow" the fuel line coming from the tank & be done.
I'm working on an inj. pump right now that the customer said the EXACT SAME THING.. I cracked it open & the entire pump was full of rust..
Some filtration systems are better than others & some inj. systems are more tolerable than others..
/ Engine speed #5
As said, back blow as there might just be crud blocking the tank screen.
Also you might simply disconnect the fuel line and see what kind of flow you'll get, bet it is minimal. (then back blow)
On TBN I read a cool trick to vacuum clean out that tank crud----you hook up a vacuum source with a container in the suction line in such a way that the crud gets deposited B4 it can be ingested by the vacuum pump.
But first ask the wife if OK to use her vacuum. LOL
/ Engine speed
I changed the filter and the fuel looked good. Started it up and again it ran normal for about 15 minutes and then started to bog. I will back blow the fuel lines and see what happens. Thanks for the suggestions.
/ Engine speed
Here's what I found. No blockage in fuel system from tank to top of injectors. When I bled the system, the RPMs dropped drastically on the first two injectors. It didn't on the back one. I took the injector out and the tip was covered with dry black smut. Now I understand how this will make it run on two cylinders. I don't understand why it would wait for 15 minutes to do it. Any comments?
/ Engine speed #8
The engine got warm, metal starts to expand..
You either have a problem w/ that injector.. a problem w/ the inj. pump OR & its a biggie..you have an engine cylinder going down.
DONT just get 1 injector!!! have them ALL checked..
/ Engine speed #9
Is this a gravity feed fuel system?
Check the vent on the filler cap.
/ Engine speed #10
IF it was DRY.. it means no fuel is being injected into or thru the injector..
I suspect the injection pump.. you say the "back cylinder".. so it will be easy to remove the steel line ON THE PUMP to SEE if fuel is coming out of it..
Do yourself a BIG FAVOR & use the double wrench method.. hold the pump "nut" while loosening the line nut.. or you stand a chance in loosening the pump [delivery valve holder] nut before the line comes loose..[not good]
You can do the same for another cylinder ON THE PUMP to compare the fuel delivery. [squirts]
/ Engine speed
It was dry. I soaked it in carburetor cleaner and it's working now. I had already loosened the fuel lines from the injector pump. Fuel pours out of the tops of the injectors. All injectors are working now. When I loosen the fuel line on the tops, the engine slows down on all 3. With the mid PTO on, it slows down more than with it off. (naturally).
2022 Kubota U10-5 Mini Excavator (A61572)
2022 Kubota U10-5...
2025 Tooth Bucket Mini Excavator Attachment (A61572)
2025 Tooth Bucket...
UNUSED SDLANCH ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
(4) 10 X 20 STEEL MATS (A64276)
(4) 10 X 20 STEEL...
UNUSED SDLANCH 14' BI-PARTING IRON GATE (A64281)
UNUSED SDLANCH 14'...
2R CULTIVATOR, 3PT (A64280)
2R CULTIVATOR, 3PT...
