engine speed using fel
/ engine speed using fel #1
mollysmaster
Upstate New York
Kubota B7610
I was thinking what speed should the enging be going while using the fel? Idle or just above or at 2500 rpm? Is there any difference in the lift at a higher RPM or is it all about the same only a little slower?
/ engine speed using fel #2
I was moving some packed (been piled for more than a year) top soil today. I ran the engine around 1600 to 1800 rpm in low range and found it was generally easy digging into the pile and lifting a bucket full of top soil. In a few places the soil was really hard and I found that I had to bring the engine to 2300-2400 rpm to really get her to dig into the pile. Last week I moved a lot of wet rotting wood chips and found it easy at 1500 rpm in medium range.
/ engine speed using fel #3
I have found that running RPM's 1500 to 1800 gives me all I need for hydraulic power and speed of the FEL. I have a gear drive so that may make a difference.
I feel I am less likely to break something by going at it a little easier. The lower RPM's kind of slows everything down so I can see wants going on and get a better feel for things.
Randy
/ engine speed using fel #4
You will have more pressure from your hydraulics at a higher rpm than at an idle. My tractor won't lift very much at an idle. You should run the engine somewhere above 1500 to have decent pressure.
/ engine speed using fel #5
Usually I run the B7100 hst at near full throttle for all work. Just seems to work better at that RPM.
Egon
/ engine speed using fel #6
1,500 to 1,800 rpms always works for us.
/ engine speed using fel #7
What does your manual say? I'd guess 2000 rpm, plus or minus 200, and that seemed to work best for me.
/ engine speed using fel #8
It really depends on the job. The hydraulics are at the best when at or near full throttle. Tough to justify for many jobs we do with loaders but it is good to remember that if used at to low of RPM it could cause problems with the pump cavitating and premature failure. If your are asking it to dig hard, pull the throttle on hard.
/ engine speed using fel #9
My B2400 operates comfortably at approx. 1900rpm's. It seems to have all the hydraulic power as at higher rpms, but uses less fuel and still has good response time.
/ engine speed using fel #10
A retired tractor mechanic who put in 40 years fixing JD's, Case, IH, Kubota's and several other brands advised me that generally 2000 RPM or so for most all FEL work is fine unless more power is required. Then he said, give it all she has! He feels that running at full throttle at all times only wastes fuel and you really do not gain any benefit unless you are pushing the machine to it's limits. I tend to believe him since he has repaired most everyone's tractor that I know and they all call him the wizard or "doc".
/ engine speed using fel #11
I think it will depend on the particular tractor model, and how the pump is set up. I normally run 1800 to 2000, but I need to go to 2400 or so to get maximum lift. Often I'll set it up at 1800, and use the foot throttle to goose it before I dig in.
/ engine speed using fel #12
jeez..
I thought that running up the RPM's gave you speed only, never thought of increasing it for more power.....what an idiot!
I always run near idle, figured if it couldn't lift it because the bypass was kicking in...
thank God fot tbnet! /forums/images/graemlins/laugh.gif
/ engine speed using fel #13
to add my 2 cents i usually run about 1800-2000- rpm when working with the fel, unless it is really easy stuff, but i find 1800 to be adequate for most fel work.
/ engine speed using fel #14
Well, it does speed it up too - and if I don't need the lifting power, I often find the faster response to be anoying, which when combined with the increased racket, is why I usually keep the RPMs down. Essentially, turning the pump faster gives more pressure and volume, which I think correspond to power and speed, respectively. The bypass will limit the pressure, and the pump will have a maximum volume it can move.
/ engine speed using fel #15
I run at 1500 or below, a 4330 Kobato. I did slow unless it's some brought in fill dirt or something like that. I need me a tooth bar I think.teddydo
Skid Steer Deluxe Hitch Plate (A65640)
Skid Steer Deluxe...
Hydrapack 6 Row Lay-By-Rig (A64127)
Hydrapack 6 Row...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
John Deere 12ft pull-type cultimulcher, Orion, IL (A65640)
John Deere 12ft...
Corral Walk Through Gate (A66408)
Corral Walk...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
