Engine RPM
/ Engine RPM #1
DOUBLEG
Saskatchewan, CANADA
Task Master 438
My Task Master with a TY395 engine has a habit of lossing RPM as you work. This happens whether using the PTO or not. If you are running at 1800 it will slowly drop down to 1600. You then move it back up to 1800 until it slips again.
Is this likely just a linkage problem?
Thanks.
/ Engine RPM #2
Are you talking about the hand throttle slipping back? If so my jinma with similar engine did the same thing and there is an adjustment , where it is now I forget, but was a simple device. check out the linkage it should be apparent. it was a long while back when I had to adjust mine and it has staid put..
Mark M
/ Engine RPM #3
If it is the hand throttle, there is usually a friction disk with an adjustable nut and usually a jam nut that makes the throttle lever stiff enough to hold position, check where the lever mounts to the tractor, it should be there
/ Engine RPM
It is the hand throttle that is slipping. I will check the linkage.
Thanks.
/ Engine RPM #5
More than likely that's what it is, like Chip said. On mine, the nut to tighten (slightly) is under the dash near the steering wheel shaft. You'll see it when you move the hand throttle linkage. Tighten that a little. I just had to do mine for the same reason.
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2021 JOHN DEERE 410E SERIES II OFF ROAD DUMP TRUCK (A65053)
2021 JOHN DEERE...
2013 JCB 506-36 TELESCOPIC FORLKLIFT (A65053)
2013 JCB 506-36...
Bobcat 84in. Loader Bucket Skid Steer Attachment (A64553)
Bobcat 84in...
1995 Ford LT9000 Tri-Axle Dump Truck (A64556)
1995 Ford LT9000...
Ford Metal Tailgate Metal Decorative Sign (A64557)
Ford Metal...
