Engine Overtemp
   / Engine Overtemp #11
Just a quick check of function: did you try warming your old thermostat to see if the center pin would emerge? When hot, it should look like the one on the right, i.e. pin out.
Thanks for the warning to look carefully at the fins. It is on the list now.
All the best,
Peter
Not sure why the picture did not come up.... Old on the left, new on the right
   / Engine Overtemp
I am calling the Deutz place on monday. Longs story but I had to take the thermostat out after installation. I found that when istalled, the little silver was pushed in. The secondary dome was still correct and pushed out.
Road graded today. Never got above 180.
As for the fins, on occassion I use water to clean the engine. My thought now is that maybe it was not correctly or thoroughly flushed and maybe it turned to mud and dried.
   / Engine Overtemp #13
i usually use a HF engine cleaner wand and notice a big difference when I soak the cooler with something like simply green - just air does not cut it.
Ken
   / Engine Overtemp #14
Close inspection on a regular basis with air/water/cleaner/degreeser or combination of above, and after cleaning inspection to make sure the fins are indeed clean and air can pass through sounds like an excellent method to keep the cooling system at it's best efficiency. Just be carefull to not use too high pressure water so to not do damage to the fins/tubes.
   / Engine Overtemp #16
So, keep a wench handy, just in case.:laughing:
   / Engine Overtemp
Just a note... Mowed a neighbors field yesterday. 2 hot hours in95 weather and the machine never got to 200 degrees. This is far better than I have ever had. I am wondering if the new thermostat allows for greater flow into the cooler. New temp sensor arrives today from Germany. Maybe this weekend....
   / Engine Overtemp #18
I am glad you found the problem. Thanks for sharing.
   / Engine Overtemp #19
Well, while we are waiting for Marrt to send us nifty FLIR photos :) of his tractor, I have to post a correction to my prior price comment. FLIR cameras aren't $20,000 anymore. There is now a $350 add-on camera back for the iPhone 5/5S that takes FLIR photos.
All the best,
Peter
FUEL CELL (A58214)
FUEL CELL (A58214)
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
