engine oil
   / engine oil #1
missedshot
Quitman, TX
CaseIH 95C
have a new 95C and would like to know if these engines perform well or not when fed Shell T6 or stick to case brand of oil?
   / engine oil #2
I have always used one of the Shell Rotella oils in all my diesels. I would advise that if you switch from the Case oil, you should go with a larger name brand such as Shell Rotella or Chevron Delo and you will be fine.
   / engine oil #3
Case doesn't refine oil. One of the major manufacturers does it for them.
Like Tom said, just use a good name brand diesel rated oil and you'll be fine.
   / engine oil #4
G'day I have been told that Fuch's supplies the oil for initial fill to alot of manufacturers case included, a grren machine owner took alot of convincing that JD did not refine their own oil until I showed him the small fuchs logo on the drum.
Jon
100 GAL FUEL TANK W/PUMP (A52472)
100 GAL FUEL TANK...
2023 John Deere 324G Skid Steer (A53342)
2023 John Deere...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
