Engine Oil temperature
/ Engine Oil temperature #1
maxton
Hey folks great forum.
I have an l5030 with about 1700 hours and I could not be happier. My question is I checked the engine oil temp at the oil filter and it reads 215 degrees. Is this too hot? The tractor is not running hot. Any thoughts
/ Engine Oil temperature #2
Dont have one, but, normal oil temp is usually 20-40 higher than water temp, so 215f would be good for a 195f thermostat.
/ Engine Oil temperature #3
At full operating temperature, oil temp will run 190F to 220F, keeping the water condensate out of the oil. 240F is a red flag. Philip.
Thanks for the replies. I was unsure if I had a problem or not.
/ Engine Oil temperature #5
Use to see 220-230 all the time on a naturally aspirated diesel. I am sure a turboed engine would run even higher temps. If yours is running 215* then its right in line where one would expect it to be.
UNUSED ATS GAC40Y 40 GAL.AIR COMPRESSOR (A62131)
UNUSED ATS GAC40Y...
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2014 Volkswagen Passat TDI Sedan (A61569)
2014 Volkswagen...
UNUSED RAYTREE RMSG29 - 29" HYD STUMP GRINDER (A62131)
UNUSED RAYTREE...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A63118)
Mahindra 4550-4L...
