engine oil options
   / engine oil options #1
cptdave
Bronze Member
New Hampshire
Kioti CK-20,Wheelhorse 4-14-8
What engine oil do you use in your CK-20?
   / engine oil options #2
I used Mobil Delvac 1300 Super SAE 15W40...from Walmart.
   / engine oil options #3
You can use just about any oil marked Diesel that has from rating of at least CD. You may go up, CE, CF etc. Here's a good article on diesel oils. John
Diesel oils
   / engine oil options #4
</font><font color="blue" class="small">( I used Mobil Delvac 1300 Super SAE 15W40...from Walmart. )</font>
"Used" or still use?
   / engine oil options #5
I USED it at the 50 and 100 hr service...and most likely will USE it at the 200 hr too...so i guess you can say I USE it... /forums/images/graemlins/grin.gif
KJ, Does that apply to synthetics ie,Shell Rotella 5w-40?
   / engine oil options #7
/forums/images/graemlins/cool.gif Gotcha.
   / engine oil options #8
I personally wouldn't use anything less than 10W40 in warmer weather, and do use 15w-40. The only real advantage I see in the synthetic is if you're not going to use the tractor and change the oil often enough to avoid chemical change damage. Regular oil I would change every 4-6 months regardless of use, but with synthetic, that would not be neccessary. The owner's manual does not have anything at all about synthetics, but they do recommend 10w40, no 5w. You might right to customer_service@kiotitractor.com and ask them about it. John
   / engine oil options #9
</font><font color="blue" class="small">( Does that apply to synthetics ie,Shell Rotella 5w-40? )</font>
I run Rotella T 5w-40 synthetic in my DK 35. Works fine !!
Thanks,KJ. I will post their reply. Dave
2017 Kubota SVL95-2S (A47384)
2017 Kubota...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A51222)
LINK BELT LB-98...
2023 KAWASAKI MULE (A51243)
2023 KAWASAKI MULE...
J & M 30' Head Cart (A50514)
J & M 30' Head...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50774)
UPDATED INTERNET...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51242)
2024 AGT...
