Engine oil in your 4110
/ Engine oil in your 4110 #1
Hypernix
New Brunswick, Canada
John Deere 4110
Hello 4110 owners!
Just a quick question, what type of engine oil do you use in your 4110? Last year I used JD's Plus 50 (15W40) following the dealer's recommendation. This year after browsing on the Deere web site, I found this document CCE Utility Tractor which suggest that I should use JD's Plus 4 for the 4110. Went to the dealer and ask for a gallon of Plus 4 and he immediately told me that Plus 50 is the way to go for diesel engines.
So what is the difference between Plus 4 and Plus 50?
Thanks!
Hypernix
/ Engine oil in your 4110 #2
I use 5w30 Mobil 1 in my 4010. Changed at 13 and 113 hours so far.
Uses 0.45 gallons of diesel/hr.
Ralph
/ Engine oil in your 4110 #3
I haven't changed oil in my 4110 yet but I have used Rotella t in my 455. It was at the 2000 hour mark and still performed flawlessly. I was considering Mobil 1.
/ Engine oil in your 4110 #4
Changed break-in oil at 50hrs. Replaced with Rotella 15-40.
Winter came, changed to 5-40 Rotella synthetic. Summer coming, I will go back to regular Rotella 15-40. Have a total
of 91hrs. on 2004-4110. have had no problems with the tractor. Runs great, starts great. {once I got the hang of it}
Have no idea what Plus 4 or Plus 50 means. sorry
/ Engine oil in your 4110 #5
Wow, some of you guys change oil quite often! My dealer told me they recommend changing the break-in oil at the recommended hour-mark, and putting more break-in oil in again, for another break-in period. They have found better-seated rings and longer-lasting engines this way.
/ Engine oil in your 4110 #6
Oh come on, these engines are good for like 6000 hours, how much longer would it make them last. They don't even break cars in anymore, and they do very well. /forums/images/graemlins/laugh.gif
/ Engine oil in your 4110 #7
I would highly recommend Plus 50 (Deere's Diesel Engine Oil)-the Plus 4 does not have the TBN (Total Base Number) that the Plus 50 has. As far as Mobil One goes, I do not believe it has enough TBN-I believe it is about 1% Sulfated Ash (should be 1.3-1.6%). Rotella T is fine, as well as their Synthetic (they are both rated for Diesel specifically)-
Hey thanks everyone for your answers! I now feel better about my dealer's recommendation to go with the Deere Plus 50.
Now I have another "newbie" question: I'm only putting about 50 hours/year on my 4110. Were I live, temperature varies from 30C to -30C. Should I change oil twice a year and use 15W40 for the summer and 5W40 during the winter?
Also I have a block heater and usually let it heat for a couple hours before starting the tractor when the temperature is below 10C.
Thanks!
Hypernix
/ Engine oil in your 4110 #9
Mobil-1 is not recommened or made for diesel engines it's a gas motor synthetic oil. If your going the synthetic route with Mobil, you need Mobil Delvac-1 or Amsoil which is also made for diesel motors.
/ Engine oil in your 4110 #10
If you look in your manual, it only shows the 5W good at about 5 degrees colder than the 15W. And at only 50 hours use, I would use the 5W all year. The W just stands for winter grade. The 40 is what the oil is protecting at running temp. Or in other words the 5W will pour at what a 5 would pour at, and the 15 would pour at what a 15 would pour at, Whicn makes it easier to start in cold weather. Then both will do their job. When they are both hot, you probably could not tell the difference if you took some and checked it for thickness. That is how it was told me, from a man that worked for a oil company for many years.
/ Engine oil in your 4110 #11
Change twice a year and use the block heater.
Egon /forums/images/graemlins/grin.gif
/ Engine oil in your 4110 #12
The 5w40 oil will have a higher viscosity at starting temperature than at running temperature and give you better starting in the cold. Why not use it year round?
I use 5w30 in my 4010. That's what the chart says to use.
Mobil 1 is clearly diesel rated. I'm using it in my 240D Benz and changing once/year instead of twice/year with dino oil. In it, I use 5w40 because Benz recommended 10w40 back in 1983 for it and I KNOW that the 5w40 is heavier at start than at running temperature anyway. Many Mercedes Club members are using Mobil 1 in their diesels. The main thing you have to watch is soot buildup. That's why you can't run Mobil 1 to 15,000 miles like in gasoline engined cars, but I figure it's good for 6,000 miles because even the dino oils were rated for up to 5,000 miles on my Benz.
I worked 31 years for Exxon as a lubricating oil process engineer. Have calculated oil viscosities many many times and have written computer programs to compute such. Your 5wxxx oil will be HEAVIER at starting temperature than at running temperature, guaranteed. So, it's silly to switch to 15w40 for the summer.
Ralph
Guys,
Thanks for all the info! This site is trully the best place to learn this stuff!
Hypernix
/ Engine oil in your 4110 #14
Yes Ralph, that is what I said to, except you explained it a lot more and better. He says he only puts about 50 hours a year on it, boy would that be a waste of oil and money to change it summer and winter, when its not needed.
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
Auger Drill Bit Skid Steer Attachment (A61572)
Auger Drill Bit...
Informational Lot - Financing (A63688)
Informational Lot...
