Engine Oil in UDT
/ Engine Oil in UDT #1
shea1004
Dillsburg, pa
Kubota MX5400DT
I changed the hydrolic filter on my MX5400 and was attempting to replace lost fluid. Instead of grabbing the UDT2 I pick up a jug of new Kubota engine oil and dumped in a 1/4 to 1/2 quart before I realized my mistake. Should I drain the hydrolic fluid and replace with fresh or will the small amount of contamination be fine? Thanks in advance for any advice.
/ Engine Oil in UDT #2
I wouldn't worry about it. Less than a quart won't make a different when mixed in with 11+ gallons already in the transmission housing.
/ Engine Oil in UDT #4
I agree, no problem at all. Engine oil, in a pinch, can be used in almost anything that requires any type of oil.
/ Engine Oil in UDT #5
In fact, in John Deere commercial (yellow) machines they now allow a choice of either using Hy-Gard trans/hydraulic oil, or their Plus-50 engine oil. It's up to the customer.
Plus, if you ever rent an implement you have no idea what oil remains in it - but it is more than a quart for sure. So Trans/hydraulic oil needs to be cross compatible with just about everything.
rScotty
/ Engine Oil in UDT #7
I'd change it. But I wouldn't be able to sleep thinking about it and if anything did ever happen that would be to blame
/ Engine Oil in UDT #8
It was clean oil, I wouldn't worry about it. I would worry about hooking up a rental implements hydraulics to my machine. Could have been on a machine with contaminated oil in it.
If it was a gallon or more of engine oil I might start thinking about draining it. But not at 1/2 a quart. As others have said oil is pretty similar generally & engine oils is speed for some hydraulic systems.
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
2006 BOBCAT 5600 TOOLCAT UTILITY WORK MACHINE (A63276)
2006 BOBCAT 5600...
Trump 2025 Sign (A64557)
Trump 2025 Sign...
2013 CATERPILLAR TH514C TELESCOPIC FORKLIFT (A65053)
2013 CATERPILLAR...
2019 CASE CX57C EXCAVATOR (A65053)
2019 CASE CX57C...
2022 EZ-GO ELITE...
