Engine Oil in UDT
   / Engine Oil in UDT #1
shea1004
Dillsburg, pa
Kubota MX5400DT
I changed the hydrolic filter on my MX5400 and was attempting to replace lost fluid. Instead of grabbing the UDT2 I pick up a jug of new Kubota engine oil and dumped in a 1/4 to 1/2 quart before I realized my mistake. Should I drain the hydrolic fluid and replace with fresh or will the small amount of contamination be fine? Thanks in advance for any advice.
   / Engine Oil in UDT #2
I wouldn't worry about it. Less than a quart won't make a different when mixed in with 11+ gallons already in the transmission housing.
   / Engine Oil in UDT #4
I agree, no problem at all. Engine oil, in a pinch, can be used in almost anything that requires any type of oil.
   / Engine Oil in UDT #5
In fact, in John Deere commercial (yellow) machines they now allow a choice of either using Hy-Gard trans/hydraulic oil, or their Plus-50 engine oil. It's up to the customer.
Plus, if you ever rent an implement you have no idea what oil remains in it - but it is more than a quart for sure. So Trans/hydraulic oil needs to be cross compatible with just about everything.
rScotty
   / Engine Oil in UDT #7
I'd change it. But I wouldn't be able to sleep thinking about it and if anything did ever happen that would be to blame
   / Engine Oil in UDT #8
It was clean oil, I wouldn't worry about it. I would worry about hooking up a rental implements hydraulics to my machine. Could have been on a machine with contaminated oil in it.
If it was a gallon or more of engine oil I might start thinking about draining it. But not at 1/2 a quart. As others have said oil is pretty similar generally & engine oils is speed for some hydraulic systems.
2018 JLG 2632ES 26ft Electric Scissor Lift (A50322)
2018 JLG 2632ES...
2000 International 4700 Truck (RUNS) (TITLE) (A50774)
2000 International...
Cat 277 Skidloader (SALVAGE) (A50774)
Cat 277 Skidloader...
2011 Chevrolet Silverado (A50120)
2011 Chevrolet...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
CFG Industrial MX15RX (A50121)
CFG Industrial...
