Oil & Fuel Engine Oil in transmissions ??
/ Engine Oil in transmissions ?? #1
CurtisJ71
Dickson,TN
Allis 5050, JD 1050
I just purchased an Allis Fiat 5050. Before starting to use it, I wanted to replace all the fluids, it's been sitting idle for months. I got the operators manual today, and under engine oil it says Multi-viscosity "Allis-Chalmers Power Lube 15-40. I'm using Rotella 15-40, and have been for years, so no problem there. But what is really confusing me, is that under Transmission & Hydraulic Oil, it also says to use "Allis-Chalmers Power Lube 15-40. Have I been around automatic transmissions to long :confused:? Does it seem right to use engine oil in the transmission and hydraulics systems ???
/ Engine Oil in transmissions ?? #2
I'm thinking typo? Dang, I'd want to triple-check that with some experts before proceeding.
/ Engine Oil in transmissions ?? #3
My Scag ZTR calls for 20-50 motor oil in the hydro and that is what I use.
/ Engine Oil in transmissions ?? #4
Engine oil makes excellent hydraulic oil except for one thing - it is very expensive in comparison. Don't be afraid to use it. The company I retired from - yellow machines, start with Cat..., actually ships some machines to high ambient temp dealers (Middle East) filled with 15W-40 and all of the medium and small equipment lines specify 15W-40 in ambient temperatures exceeding 104 Fahrenheit (40 Celsius).
/ Engine Oil in transmissions ?? #5
Several older tractors used 10w30 or 15w40 in engine and hydraulics. I think I even read some older Skid steers did as well. Makes life easier when you can just buy a couple 5 gallon buckets of it to keep around.
/ Engine Oil in transmissions ?? #6
I've got an older JD mower with a transaxle that takes 10W30. Works great.
/ Engine Oil in transmissions ?? #7
A friend of mine had a 5050 years ago which I use to operate on occasion. One of the things I liked the most was the 12 sp transmission which had several gears below 2 mph, this would make a good tractor for operating a rototiller. The hydraulic fluid capacity was limited but don't remember the exact amount. Hope the tractor works out for you.
/ Engine Oil in transmissions ?? #8
I too would like the answer to this.
/ Engine Oil in transmissions ?? #9
I had a JD that spec'ed 10w30 in the motor and hydraulics. I am no expect but 15w40 would seem a little heavy for most conditions as hydraulic oil.
/ Engine Oil in transmissions ?? #11
I love the education I'm getting here!
Wasper67, have you ever changed the primary fuel filter on your 5050 ? I've read the operators manual instructions and they are intimidating. I'm fairly mechanical, but I am not a mechanic by any stretch of the imagination.
Hydrapack Lay-By-Rig (A64127)
Hydrapack...
Front Tank Bracket (A64126)
Front Tank Bracket...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
2007 DRAGON  130BBL VACUUM TRAILER (A65643)
2007 DRAGON...
John Deere 3025E (A64126)
John Deere 3025E...
2021 KOBOTA SVL 97-2 SKID STEER (A65053)
2021 KOBOTA SVL...
